mourip
To those using an Antelope LiveClock with their RNs, what do you call the power supply cable used for the LiveClock, which is a screw on? I'm looking for an umbilical cord cable from an external lps to the LiveClock.
You can use a standard DC connector like the kind that usually comes with an LPS. My HDPlex had one that fit perfectly. It is a two terminal barrel type connector. I cannot remember if it is 2.1 or 2.5 mm.
It does not need to be the same "safety" screw-on type. The regular type just slips inside as it normally would.
