motberg
I think SOTA USB actually requires serious attention to the computer itself, especially power supply, and always some type of galvanic isolation in the path.
Galvanic isolation comes free with AOIPI think SOTA USB actually requires serious attention to the computer itself, especially power supply, and always some type of galvanic isolation in the path.
I added fiber to my setup a week or so ago but started with it between my switch and my PC. My PC has two ethernet ports with one dedicated to DVS. I cannot say this made a difference.
A couple of days ago I moved the two FMC's and the fiber connection to the link between my PC and my D16. This made a difference although it was subtle.
This afternoon I replace the supplied SMPS to the FMC that is on the D16 end of the link with 9V from my HDPlex LPS. This made a noticeable positive difference, giving me a cleaner sound and more distinct instrument positioning.
Thanks for letting us know about your own experimentation.
Hey Paul,
I'm wondering how far apart you've placed your D16 from from your PC.
Mine is only about five feet apart and I'm wondering whether optical cable could make much of a difference over such a short span.
I have the FMC's and linear power supplies to give all of this a try but wanted your opinion.
Also, how far away from the D16 and PC are you placing your FMC's?
Thanks in advance for the information.
Joel
My D16 is basically sitting on top of my PC/Server. I do not think that distance is the culprit as in an opportunity for interference to be induced on the cable from the environment. I think that the fiber basically stops cable noise that may come along regular CAT5/6 cable from the PC dead in it's tracks.
JABBR is the LAN isolation king so hopefully he will weigh in.
I don't know if there will be any comparing with Mivera Audio.
Mivera Audio is going to be a 100% closed brand system.
Hi guys. Just getting up to speed on audio over ip and planning to take the plunge soon.
Anyway, I wanted to ask about the statement I quoted above. I thought the upcoming Superstream Pro (Ravenna) can be used with any server using the virtual sound card. Additionally, can't the Superstream Pro output to any DAC as well?
From Mike:
Looks like we're going to ditch the option of no internal storage with the Superserve. And increase the storage option up to 16tb. That should be enough for anyone. So storage options will be:
6/8/12/16tb.
This is the only way to ensure 100% perfect reliability. This takes all outside variables out of the equation. Folks who want to use a NAS can go for our free OS download.
Question:
the PureStream Pro (having an internal Ravenna board) will take input from any Ravenna VSC as long as it is in DSD256 format?
Mike replied:
It all depends on what we end up upsampling to. It might end up being 33.33mhz. The Superblock system will be built to work with the Superserve.
I find that Mike makes this whole product proposition extremely confusing and intransparent, by not giving any insight in what product use what protocols and how they may be connected with products outside of his own brand.
All extremely confusing and focused on a closed brand topology.
Thank you jabbr. I totally agree its very confusing. I am mainly interested in the proposed Ravenna Pro device which according to Mike's post on CA yesterday, sounds similar to the Rednet. Interestingly, that post describing the Ravenna Pro as well as his other posts are now deleted at CA. I do not know Mike but it seems he keeps getting banned from sites???
