Ultra Slim Portable Audio Amplifier and USB DAC
for your smart phone
USB DAC (Digital to Analog Converter)
for your smart phone,
presenting new listening experience
Richer and Wider Palette of Sounds in Your Pocket
- Battery powered DAC / amp
- 8 hours battery life: 1750mAh
- Power ON/OFF auto detection
- Sabre ES9018K2M 32bit DAC for 100% native decoding of PCM and DSD / DXD
PCM : up to 32bit / 384KHz PCM
DSD : Native DSD
DSD over PCM(DoP)
DSD64 (2.8224MHz), DSD128 (5.6448MHz)
DXD(24Bit/352.8KHz)
- Sample rates :
44.1KHz, 48KHz, 88.2KHz,96KHz,
176.4KHz,192KHz, 358.2KHz, 384KHz
- Outputs: 3.5mm Earphone Out
- Output level: 1.9Vrms(No Load)
- Output impedance: 1.2ohm
- S/N Ratio: 113dB @ 1kHz
- Cross Talk: 124dB @ 1kHz
- THD+N: 0.008% @ 1kHz
Compatible with IOS and Android OS
Controllable by iPhone and other Smartphone applications
Mastering Quality Sound (MQS) Headphone Amplifier
Ultra Slim High Definition & High-Resolution USB DAC
This Portable Smart-Fi USB DAC & Amplifier is designed to present brand new experience of music listening directly from your smartphone, converting digital audio signal into the High-Res Smart-Fi analog sound. This will allow you to get the professional MQS sound by simple connection of Opus#11 directly to your device, serving as a medium and portable amplifier, to present the highest quality studio sound wherever you go.
Opus#11 is probably one of the best possible solutions for your
High-Res audio experience you may ever find at the market. Super Ultra slim
7.9mm metal body comprises the high-end technology in the
DAC area.
The Bit has come up with a revolutionizing remedy to bring the unheard before sound to your daily life, whether you are commuting to work or enjoy your favorite music at home, in order to make
MQS accessible to the masses.
The XS1-U8A-64 (XMOS) has Eight-Core Multicore Microcontroller with Advanced Multi-Core RISC Architecture. This highest 32bit processor core is designed to provide powerful performance while you go.
The Sabre ES9018K2M delivers an unprecedented level of performance and spectacular sound quality up to 110dB dynamic range and 0.008% of total harmonic distortion
Opus#11 presents an ideal solution for stereo conversion from digital audio input in DSD formats of up to 32bit/384kHz.
General specifications
Body Material[Design]
Aluminium[Slim] 7.9T
Dimensons[mm) [T.B.D]
56*103*7.9T
Weight
80g [T.B.D]
Battery Capacity
1,750mAh / 3.7V[T.B.D]
Playing Time
8Hr[T/B/D]
CPU
XS1-U8A-64 (XMOS)
DAC
Sabre32 ES9018K2M (32bit DAC)
OUTPUT IMPEDENCE[T.B.D]
1.2 ohm
OUTPUT LEVEL[T.B.D]
1.9Vrms(No Load)
S/N Ratio[T.B.D]
113dB @ 1kHz
CROSS TALK[T.B.D]
124dB @ 1KHz
THD+N[T.B.D]
0.008% @ 1kHz,
FREQUENCY RESPONSE
20Hz~20KHz (0.03dB)
USB Input Interface
USB AUDIO 2.0 / 1.0 , asyncchronous
Supported Audio Formats
(T.B.D)
PCM :
DSD :
Native DSD
DSD over PCM(DoP)
DXD(24Bit/352.8KHz)
Sample rate :
44.1KHz, 48KHz, 88.2KHz,96KHz, 176.4KHz,
I/O
USB 2.0 IN (MICRO 5PIN)
DC JACK-IN (5V/1.2A)
EARPHONE-OUT (3.5pie)
LED INDICATE
LED1: CHARGE LED
LED2: BATTERY LEVEL / USB CONNECTION
Supported O/S
[t.b.d]
Windows XP/Vista/ 7/8.1, Mac OS x10.6.4 or later, Android(4.4 or above), iOS7/8/9
Accessory
(Package)
T.B.D
Phone Battery was draining fast
Started the phone
Started the OPUS by plugging in headphone...then connected both after both turned on.
Seems to have fixed that issue.
