- Jun 4, 2014
I'll say yes only because I don't know of any other threads discussing reasonably-priced measurement hardware. (I'm not talking about DIY couplers that you can make out of vinyl tubing, etc. I know that's been discussed elsewhere, but a totally build-your-own coupler approach makes it ridiculously challenging to compare measurements from different rigs.)Is this still the main thread to discuss reasonably accurate and not outrageously expensive DIY measurement rig setup?
Appreciate the enthusiasm and any future contributions(I ordered a coupler & pinnae yesterday and hoping to be able to contribute to measurements). If so, I plan on documenting and sharing what I learn getting my rig setup here =).
Also started thinking about how to crowd source measurements in a responsible way. Should that be discussed here or in another thread?
That could be the logical conclusion of all this. If there were enough enthusiastic measurement peeps out there willing to contribute to a larger community-supported database I'd be happy to try and get it hosted somewhere like HypetheSonics.com. But there are some issues we'd all need to work through first:
1) Coupler/mic variation. There are some very good clone couplers out there, but in general, you're going to get a larger variation between clone couplers than you would between GRAS/B&K/Larson Davis, etc., couplers.
Some clone couplers come with mic calibration files, but even if they do, they seem to be of fairly poor quality. You could use this tour kit to calibrate a 711-clone rig against a GRAS RA0045: https://www.head-fi.org/threads/ety...phone-for-your-ears-and-your-couplers.908512/ (@earfonia recently did this. It's a bit of work, but his results are now in excellent agreement with the RA0045 across a broad range of IEMs.)
2) Measurement procedure/preferences would have to be common. For example - foam tips or silicone? Small, medium or large tips? There are a surprising number of people out there who still believe that measurements aren't accurate unless you see an 8 kHz resonance peak in the graph. Some insist on always adjusting insertion depth to give an 8 kHz resonance peak; others only sometimes. Many a good database has been essentially ruined by nonsense like this, because you then can't make a fair comparison between IEMs designed for shallow vs deep insertion.
Dumping everybody's data into one giant database would be the easy part. The challenge would be ensuring that what we'd be comparing would be consistent from rig to rig. It would only take a few bad contributions to warp all the statistics and make comparisons meaningless or, at best, uncertain. I'm happy to pursue this if there's an interest, but a global database would mean contributors needing to do a bit of leg-work first and potentially getting vetted or screened to ensure their data would be of sufficiently-good quality, and that they'd be agreeable to following a common procedure. I suspect that last part could be challenging
