tim3320070
Not useless for me- I have the Master-5 and I can switch back and forth without needing the extra cable banging around. But it is a little odd.
I'm gonna be paiairng it up with the DT990s which is very bright. Sounds like a quality combo. I may even go old school Hifiman and get the HE-4 which could use all that power.
Unless you really like the HE-4 sound signature and your budget does not allow you to get the HE-5LE (which has a similar signature) I would not recommend this phone. I own it as well as the HE-500 and the performance level is definitely not the same. From what I heard, the HE-400, however, is really close to the HE-500 in most aspects but it has a dark sound signature that might not pair well with the SA-31 in this case. I would go NFB-6 + HE-400 or SA-31 + HE-5LE depending on budget.
The SA-31 is not dark- it's "Kingwa dark" meaning subtly warmer that ultra neutral.
Exactly. Having owned the NFB-5, I know what to expect.
The NFB-5 sounded glorious with the HE400. Since the HE-4 is slightly brighter than the HE400, I wouldn't expect overly dark sound anyways.
First things first: waiting for the SA-31 to arrive to test with the two 990s I have. Then I'll see if I have a desire to get the HE-4.
PLEASE tell me that means it's on it's way!
Yes, it's on the truck for delivery
It's here!
