Sorry, yeah, wish. Dunno why I wrote with. :rolleyes:
Maybe you are having so much fun, you are developing a lithp?
Well, yes... digital up/down buttons are no match to knob turning intuitivity. It takes some time to get used to buttons.
But beside that - it performs flawlessly: it is not in signal path, channel imbalance is non-existent (useful in late night low level listening), has enough steps and gain settings are well chosen (+10dB/+0dB). I've opted for additional volume board (+5dB/-5dB), but had not have reason or urge to swap it in yet.
OtOH, you can get remote which sets you back for additional $50 which is,perhaps, a bit steep compared to whole unit cost... it is "indestructible" (aluminum) but rough on some edges (DIY fixable)... it has no repeat feature for volume up/down functions which KingWa explained as intentional - so that unit does not mix-up remote commands; not so sure this was not doable but funny thing is you can change volume faster with fast repeated presses on remote control than with holding volume up or down button on SA-31... it has no mute button (workaround: swap to "empty" input channel)... it has no standby (on/off) button... and I miss the most a button to dim or turn off the display (yes... again lazy late night listening).
Knowing all this now - I would order remote again... it is priceless in certain lazy lay back moments.
kingwa said:The NFB 5 have the ALPS volume control port, but the SA31 have the relays volume control board, the ALPS port must have the channel imbalanced but the relays volume control without channel imbalance.
We can't change the SA31 to knob control.
Kingwa
Ah well, ordered the SA-31 with remote control and two 6.3mm inputs. I have zero use for XLR.
