Apparently, bypassing the DSP1 also defeats oversampling, which is kind of a problem
However, I might have nailed down my issue with the Ref 7.1. Some high res material at 24/96 sounded absolutely stellar (talking only from a timing perspective), while regular CDRB format file simply did not. But if I am not mistaken, I realize that the master clock of the DSP1 only supports 32khz and 48khz (256Fs, 384Fs, 512Fs and 768Fs). So I decided to use Pure Music excellent SRC build in engine to upsample everything to 24/96. Improvements were obvious in my system when playing back native CDRB files. I am very curious to hear what other Ref 7.1 owners think about this.
I have a REF7. Ive played around with the DSP-1 jumper setting and have heard marked changes. I was surprised at what I heard as other guys said it made little or no difference and that was a consistent view so I wasnt expecting it to do anything. I wonder why others didn't hear a difference? Perhaps their gear imposed so much of a flavour on the music the changes were obscured? Or maybe the jumpers were put in the wrong pins?
There are many reason the 24/96 can sound better but the minimal preringing upsampling Izotope filter could be a huge one.
If the music was released as 16/44.1, I don't understand how resampling it would introduce any improvements unless the equipment you are feeding it through somehow works better when being fed a signal with a certain sample rate.
I would love to learn how REsampling with a higher sample rate would increase quality.
Anybody else care to comment on this?
Sample rates are essential for DA conversion to push the noise beyound the audio spectrum without creating artiacts throughout the music with filter noise.
This is the big issue with achieving analogue quality with digital storage. Basically the higher the sample rate the better for music quality or an upsampler with filter that minimises the horrible pre and post-ringing artefacts.
Izoptope and espiecally XXHighend-Phasure are doing that.
My prefered settings so far:
- Pure Music with target upsampling at 96khz.
- "NOS Classic" upsampling (there are 2 minimum phase upsampling method to choose from)
- PLL off
- Stopband attenuation -90dB
Sounds sublime to my ears now even with CD rips. It was certainly not the case prior to these changes.
Nice work.
That all makes sense so far.
I do leave it constantly on though, which might not be recommended.
I also quite do not like the proximity of the AC socket and power cord with the digital circuit, and especially the AP2 gets very close to the IEC connector.
Other than that, I certainly do find that the sound is improving with burn-in. I still want to let it burn-in for another 200 hours before serious evaluation.
If you want the best sound leave it on in my experience.
It might be worth buying or rigging some mains plug shielding - let us know if you hear a difference please.
I think my Ref7 took about four weeks to mature and went through some interesting phases on the way - not always reassuring for me at the time!
The RE7.1 runs.
If it have good heat dissipate, like have not anythings cover on its top board, far to the heat source, it can power on 24 X5 hours. Then want to had a restart.
Ive taken temperature reading of the REF7 using an laser thermometer and most of the components from memory ran slightly warm - perhaps just 10C above ambient room temperature. I find it takes at least an hour of being on to start sounding good and have noticed repeatedly the sound keeps getting smoother and smoother up to three days. I use very transparent speakers to notice that and I don't think I would notice with a tube amp on my HD800's even. I wonder why a restart is needed after five days? Wound the DSP-1 need restarting I wonder?
That is an interesting idea I am considering myself... It is possible to run the Ref 7.1 in NOS mode bypassing the DSP1 (hence no internal oversampling), while upsampling 16/44 through Fidelia/iZotope... I am just not that convinced that 24/96 would be enough for the PCM1704 to operate optimally for that matter... Would than even be possible at all ? It would probably need higher rates. Is it possible to send a 24/192 upsampled signal into the Ref 7.1 when bypassing the DSP1 ?
The phasure takes 24/768 if I recall correctly.
Definitely put the DSP-1 in NOS mode and check it out. It sounds to me, well different. I used SOX upsampling to push the 44.1 up to 88.2 and prefered that in NOS DSP-1 mode - lots clearer and more details while still very smooth. High res 24/96 tracks sounded better again but maybe thats the recording quality?
I think Kingwa could say if the REF7.x SPDIF receiver and DSP-1 could accept any higher sample rates above 24/96.
Somehow I doubt it.
The PCM1704 can accept 24/96 X 8 oversampling so most receivers and filters used in PCM1704 machines take a max of 24/96.
Check it out as in NOS mode 192 probably will perhaps sound even better then 96 according to theory and the trend.
Watch out for any noise experimenting like this. Use a preamp or integrated amp volume control turned all the way down and a cheap pair of headphones to start with!
I like your questions and hope you try it for yourself and report back for us?
Its doubtful anyone else has done this with iZotope filtering so believe your own ears and look after them with that volume knob.
The Phasure USB is stated to go to 24/768. That means ALL the up-sampling and filtering is in the software domain under the control of the users fingertips. The Phasure designer must be exceptional to achieve that. I think its a first. Hes also got a minimal ringing filter in the software. This is like the holy grail of this design ethos.
As good as the PMD100/200 filters are and how amazing the DSP-1 is, the XXHighend filter (if it actually performs as stated) is going to blow them all away.
As well if a better filter comes along all that is needed is a quick download, update the software and then listen for the difference. No lid to take off, no expensive filter to take out, send away for reprogramming or in the case of the early filters replace. This is clearly the way of the future. I mean now. If you have a spare 4.5 grand dropping out of you pocket that is.
