That's a bit of a tricky question. We've got a discussion over on the R2R main thread if you'd like details, but to summarize...
There were/are 2 noises that occurred during playback
- The R2R 11 had one type of (to my ears) very low level noise that was present in all DSD playback. I would not have characterized it as a crackle myself, but noises are hard for me to describe... more of a hiss/static to me. Note - to my ears this was never objectionable. I don't listen to much DSD, but if I squinted my eyes and held my nose just right, I could hear it. That noise was constant in tone and amplitude. The upgrade removed (ok technically just reduced) that specific noise. It was specific to the R2R-11 (in the current R2R line of products). Kingwa confirmed that. I never heard it with an R-1 or R-8.
- There is (what I'd describe) as a weird noise during quiet passages or "silence" with some tracks. The opening seconds of a track will reveal its presence instantly to me if it is there. That noise is present in all the current A-GD R2R DACs I own and that some others own. Kingwa is now aware of it and studying the situation. It is only with some tracks from certain sources. It does not occur with all DSD tracks.
So, in summary... what I've recommended is that if DSD is an extremely important part of a music library, then the A-GD R2R DACs may not be the best choice at this time. There's a known issue without a known solution with some tracks. With other tracks (all of the music I own) it plays flawlessly. However, I've downloaded a few of the tracks with the issue, and it is 100% there. The cause and the subsequent solution are not yet known.
Are you sure that all R2R DACs including the new R1 suffer from the quiet passage (your 2nd mention) noise DSD plague? I'm on the fence right now to change my R2R11 to an R1 because of the aforementioned problem, and the balanced outputs.
I don' t care if the first problem is there, as I'm not able to detect it, but the second one is a deal breaker by me.
