dan.gheorghe
- Mar 15, 2010
How many headphones have you tried with the Precision 2?
Can you recommend something that works "very" well with the P2?
It was a great match for both HD800 and LCD-X. With HD800 it was a delight. I never heard so much bass from HD800 and such natural sound. It also tamed the treble without taking from the sparkle and the extension.
Thanks, i was just thinking that have you had a change to try the HE-560.
So the main "top" options are either HD-800 or HE-560. Wich one you like better with the Precision 2?
Hi Dan!
I am a current owner of the HD800 and Precision 2.
The thing is I'm getting a bit of upgraditis and wondering if tube amps can improve the HD800.
My problem is this is my first high end setup and I have no benchmark to compare with. Is what I'm hearing good? Extremely good? Meh?
Make no mistake though, I really enjoy my setup and the sound gives me goosebumps sometimes.
It's just that you keep wondering if you can do better.
Hello there,
Well, Precision 2 is one of the best headphone amplifiers I have ever heard. I would take it over the tube amps I've heard until now. What you have in terms of amplifier is very good. I found that I am a bigger fan of good ss amps, even if tubes have their magic. To go better than P2 with HD800, you would probably have to buy the new HE-9 from Audio-GD.
What DAC do you have? HD800 also scale a lot with a good DAC. And when I say a lot, I mean a freaking lot.
Hello there,
I'm currently using the new Matrix Mini-I so to be honest that is the weakest link in my chain. What DAC do you feel complements the HD800?
My only requirement is an optical input as I use them on my pc and I use the optical out of my sound card for games
Have you heard the Precision 1? I'm trying to figure out if the how different the sound quality is between the P1 and the P2. My other question is which of his headphone amps is the the Precision 2 based off? Or would it be better just to ask Kingwa himself?
