Really sorry, it was I that read it wrong not you. You said you will get the
no shorting to ground configuration.
I hope you will be satisfy with the Master 9. I sure have
Ah, no problem, and thank you!
This should be my last piece headphone related for sometime. It's been LONG overdue. Very excited.
A few years back I nearly sold all my heaphone gear (Audeze, Hifiman, Emotiva, Marantz) as I was not happy with the headphone experience. Later I heard the HD 800 and found some hope. Instead of going the typical route and buying headphones first with an amplifier, I actually did it opposite this time around. I started with a good DAC and pre-amp, which also had a good headphone amplifier. Then picked up the HD 800. Then picked up the BDP-1 as I strongly wanted to get away from the computer screen and the sound.
Having done the audio journey twice with buying downstream gear first time around, and recently doing it with upstream gear first, I have enjoyed all of my gear a lot more each time I added something. I'm really happy I got the upstream stuff correct.
Nowadays, I would rather listen to a mid-fi headphone or speaker with good upstream gear (Transport + DAC), rather than mid-fi upstream gear with TOTL (headphone) amps. IME the digital components matter a lot more than they are typically given credit. With less than optimum transports, like computer (Mac, Audirvana etc), I've found no matter how good the analog, there is always going to be some digital glare that will get in the way...Maybe I'm more sensitive than others.
Anyways, back to the thread. I'm sure this time around I'll have the rest of the rig up to par to bring out the best in the Master 9.
