HE9 in da house! Been listening for 6-7 hours since arrival.
Here are some early observations of what I find compared to the M9:
In 2ch set-up: I immediately noticed a blacker background - in fact, not a sound even if I put my ears up to the speakers - and I believe this background is the key to the rest. I hear more air around instruments, voice, bass, piano. Definition is better, especially low piano notes and bass. Soundstage is pretty much the same - wide - but its like there's more space between instruments (air) which helps for clarity and definition. I also find that these improvements help me get more into the music. Thats for my findings as a preamp in the 2ch. set up.
In HP mode: with LCD-X. Cut and copy from the 2 ch. with the difference that the better bass definition is what catches my attention at first. LCD-X good bass is what makes me like those headphones but with the HE9, its all a little better, particularly where the bass (double bass mainly) is upfront in a jazz trio or duo set up - piano, d-bass, drums. Theres not more bass but its better defined, i hear the notes more clearly. I need more listening time to better evaluate the HE9 but it looks very promising.
Finally, something unexpected... I'm a big fan of Fender Rhodes and Hammond B3 sound. To my surprise, the FR and HB3 are probably the best I heard up to now through the HE9.
I read a review where the reviewer said that the HE9 lacks musicality. I'm not too sure what he means by that but I really dont find thats the case here, in my setup. To me, the music is fluid, voice are very well presented which makes it very easy to hear and feel the emotion of the singer. The feel is one of the strength in my book. I had the same finding with the M9 but just a little bit more with the HE9.
This said, the HE9 has pretty much the same general character as the M9. Its still a polite amp that could use a little bit more punch for complex prog music. For me, with the type of music I listen to 90% of the time, its a keeper. Its not night and day vs the M9. The difference is in the details, here and there, and IMO, that's what makes HE9 a worthwhile investment over M9. But I can understand that this presentation doesn't fit every taste. If I was a electronic or metal music lover, I would probably look elsewhere.
Source set-up for both 2ch and HP is Aurender N100H / Bryston BDA3. Hi-Rez files and DSD64-128, dedicated power lines, all Furutech Alpha power cables, Audio Sensibility Signature and Statement IC, balanced set up for both 2 ch and HP.
