Articnoise
Doesn't change the fact that they both accept 192 or even 384kHz signals. My point was to say they are not limited to the base frequency announced in their datasheet (48kHz for the PCM-63, 96kHz for the PCM1704) and they are guaranteed to do 768kHz. Now that we have the proper interfaces to do 384kHz, they will take it.
There's probably no point in doing oversampling past 192kHz input.
I have never ever argued that the PMC 1704 can do 192 KHz, 384 kHz or 768 kHz.
The discussion, if you missed it, was if the PMC 1704 can do 8x oversampling at 192 KHz or 1536 kHz in NOS. Maybe Kingwa has somehow overclocked the dac chips or it’s actually doing 4x oversampling at 192 KHz or.......
BB and TI have stated the PCM 1704 to be able to do 768 kHz and that is in line with how it been used in many DACs. New and old ones!
“This is the key specification for the PCM1704. Digital data words are read into the PCM1704 at eight times the standard DVD audio sampling frequency of 96kHz (e.g., 8 x 96kHz = 768kHz) to create a sinewave output of 1100Hz.”
http://pdf1.alldatasheet.com/datasheet-pdf/view/524218/TI/PCM1704.html
“Chip accepts signals up to 24/96. Both CD-5 and Skylla are equipped with upsampler changing the signal from CD to 24/192. Same thing is done with the signal from digital inputs. The interesting thing is that PCM1704K works up to 96 kHz… But obviously there is a possibility to turn off eightfold oversampling and make him accept higher frequency signal. Anyway we have four chips – two for each channel. Before signal goes to PCM1704K it is transferred via Burr-Brown's SRC4193. Than signal goes to modern, programmable DSP Seiko NPC SM5847 chip that is working as a precise signal strength control. This chip is employed also as digital filter as PCM1704 DACs don't have their own filters.”
http://highfidelity.pl/@main-75&lang=en
“The DAC itself uses a pair of PCM1704K chips by Burr-Brown, a regular feature in Naim players. But before the data makes it to the DAC itself, the datastream is read into a SHARC DSP that acts as data receiver, filter for out-of-band artefacts and acts as a 40bit, 16x oversampler and a buffer.”….. “The DAC’s big feather in its cap (aside from the uniqueness of it being the first DAC from hitherto DAC-deniers Naim) is it can handle recordings at a sample rate of up to 768kHz and at 32bit resolution.”
http://www.audiocounsel.co.uk/wp-content/uploads/2012/07/Hi-Fi-+-Review.pdf
Some more in the same line.
http://www.digitalaudioreview.net/2011/04/audio-gd-reference-71-dac-8-x-pcm1704uk/
http://www.head-fi.org/t/525954/why-do-audio-gds-pcm1704-dacs-only-accept-96-khz-1704-accepts-up-to-800khz
