Audio-Gd Master 7 - Discrete Fully Balanced DAC (PCM1704)
- Thread starter DarknightDK
yacine60180
- Mar 28, 2015
PHOTO:
AUDIO-GD MASTER 7 (USB SUPRA)
AUDIO-GD PRECISION 1 (ACSS 1M)
YAQIN MS-2A3 Upgraded Pier Audio (RCA ATOHM ZEF 1M)
HIFIMAN HE-6 MOD XRL (SYBIOSE OCC CRYO)
Youth
- Dec 6, 2014
Is there anybody who has had the chance to listen to both Master 7 and DAC 19? Curious how they compare.
ahendler
- Jul 17, 2014
Yes my friend has the 19 and I have the Master 7. I bought my Master 7 after I heard the 19. It is abeautiful sounding dac. The 7 just
has more of everything. More resolution and greater dynamics. For the money the 19 (10th anniversary edition) is a great dac and the Master 7 is simply the best dac I have ever heard.
Alan
Alan
r one
- May 1, 2013
What is (or are) the best jumpers position for you guys ?
Youth
- Dec 6, 2014
Alan
Did both of them have Amanero combo384 USB module? And did you compare them on the same setup? Thanks.
DACLadder
- Feb 16, 2013
I experimented with jumpers for months and finally went back to factory default. Changing the jumpers warmed up the M7 sound at the expense of narrowing the soundstage and fuzzier imaging for the most part (recollections from memory).
But you should give the jumpers a go as you never know what you will discover. It was a lot of fun!
r one
- May 1, 2013
i should give it a try, i haven't tried any combination yet.
Hi,
I have bought a Master 7 two months ago. I found the USB input very good so reading about Amanero I wished to upgrade the USB32 module with an Amanero but there was a problem listening with my Mac: left and right channels were swapped in a random way! Magna Hifi who made the upgrade could not understand the problem for long time and then arrived to this conclusion after several tests:
the problem is only on Master 7 DAC before 2015. And only through Mac computers. It's fine with Windows and Linux.
For Magna Hifi it would be necessary to change the DSP.
Audio GD did not help.
Then I purchased a Linux based streamer and now I have some problems of connections with my USB32 card. It is maybe a firmware problem but I find the installing guide for the new firmware not very clear. (if someone could help me!)
Now Kingwa talk about the Xmos usb module as alternative choice to USB32 and working better with Linux:
http://www.audio-gd.com/Pro/dac/Xmos/XmosEN.htm
Someone knows about it?
Flosa
- Aug 11, 2009
Maybe the easiest solution will be for you to buy an external usb module (digitale interface)
That's what i did some months ago , ok it's an another box but it's asily to instal ..and remove !!
I've bought the Melodious Mx-U8 it's Xmos
r one
- May 1, 2013
had some tries today with different settings. I'm agree with you, default settings seems to be the most coherent, or i prefer them. In nos mode, i've a little channel imbalance to the left that i haven't in default for example.
I leave the default settings and prefer playing with tubes
Make sure your NOS settings are correct. There are settings on the Audio-GD website now that disagree with earlier settings. Specifically, try with and without the IPS1 jumper for NOS mode.
yacine60180
- Mar 28, 2015
I also prefer to the original settings.
r one
- May 1, 2013
Yes i knew that. I've tried IPS1+IPS0. Only IPS1 or Only IPS0 and others combination.
Flosa
- Aug 11, 2009
I'm lazy ...i didn't play with it .Stay as it was on the 1st day !!
Total: 8 (members: 0, guests: 8)
