evillamer
- Oct 5, 2004
I have a couple sheets of AB5100(non-S), but I have next to no clue what to do with it. I've also got an 8"x11" sheet of Mu-Metal, a couple sheets of ERS paper, and some copper foil tape; yes, I kinda went to town on buying that **** up. Let's hope the dollars add up to some sound improvement.
Anyway, I don't have my system together right now so I can't actually do anything, but I'd appreciate anyone's advice on where the best places to put those things would be and any combinations that you've found useful
Looks like you spent quite a ton of $ on these materials, they add up quite abit.
Here's a few threads which will give you some tips:
http://jplay.eu/forum/computer-audio/can-the-guys-whove-used-emirfi-paper-sotm-3m-etc.-post-photos-here-of-how-you-did-it/
http://jplay.eu/forum/computer-audio/emirfi-treatment/
http://jplay.eu/forum/computer-audio/the-battle-against-harshness/
here's a photo of how this guy does it:
http://www.highend-audiopc.com/pictures/mytek-dac.jpg
ERS Paper:
http://i1368.photobucket.com/albums/ag163/richard_j_dale/IMG_0044_zpse915ed63.jpg
though my recommendation when apply tweaks/shielding like this, try to do it in small quantity/step by step as tweaks can affect sound quality adversely. If anything doesn't sound good, you can rollback/reverse to the previous setup/configuration.
example: I tried using blutack to cover up clock generators crystals and found that it resulted in a more muddy/bassy sound.
Also some materials are conductive(i.e. copper foil tape) and it might cause short circuit if you are not careful with placement near electrical components. Also beware of the thermal design limits of the chips you are placing the tweaks on. I consulted with Kingwa(audio-gd) on the placing of the 3M asborber on the Master7's DSP(he say it was ok due to the low heat output of the dsp)
From what I understand is that mu-metal is used to block off magnetic radiation(use it at transformers and other magnetic generating sources), ERS paper can be used in hard to place areas(i.e. PC casing) and the non-conductive 3m EMI asborber is usually placed on top of semiconductor chips.
The other tweak worth trying is audiophile grade fuses and power cords(either medical grade or audiophile aftermarket ones) or even power conditioning/regeneration etc.
I replaced my power cord tin-plated fuses with silver-plated cooper bussmann ones and they sounded better.
Even my schitt wyrd is extensively modded internally with 3m AB5100S.
