Audio-GD DI-20
Oct 14, 2022 at 7:17 AM Post #4,247 of 5,353
Oct 14, 2022 at 7:19 AM Post #4,248 of 5,353
As I understand it is both the termination and the resistor behind it that define the impedance.. The most reliable way to verify is to actually measure the impedance of the termination..
I received the OCK-1 today. Unlike on your picture, its female 75 and 50 ohms outputs are all the same.
What does it mean?
Oct 14, 2022 at 7:42 AM Post #4,249 of 5,353
I received the OCK-1 today. Unlike on your picture, its female 75 and 50 ohms inputs are all the same.
What does it mean?
You mean outputs? Not sure. Maybe ask Alvin? I am not very technical but I had something similar when Magna Hifi converted the WCKL output on my DI-20HE to 75 Ohm. They said they did it internally, so I guess they changed a resistor. However the visible connector was still the original 50 Ohm one just like your 3 clock outputs. It again confirms that this is underdocumented territory :-|
Maybe someone has instructions how to DIY measure the impedance?
Oct 14, 2022 at 8:52 AM Post #4,250 of 5,353
75 ohm clock cables work ok with 50 ohm connectors. But it seems dumb to do that on purpose. They should have changed to the correct connectors.
Oct 14, 2022 at 8:57 AM Post #4,251 of 5,353
I sent a mail to Alvin, asking why the customized 50 ohm output has the same connector as the 75 ohm outputs.
Oct 14, 2022 at 9:21 AM Post #4,252 of 5,353
Because the connectors were 0,5 euros for 3 pieces on Aliexpress? :p
Oct 14, 2022 at 9:24 AM Post #4,253 of 5,353
It means they are not very precise in what they do. I also believe they are not precise in measuring the phase noise of their products.
And the impedance of a clocking circuit is more complex than putting in a 50 or 75 ohm resistor.
Oct 14, 2022 at 10:05 AM Post #4,255 of 5,353
I believe it is common practice amongst EC manufacturers.. Mine (Morion) is adjusted the same way: I have 3 identical terminations, but one of them is 75 Ohm (different resistor).
Oct 17, 2022 at 2:38 AM Post #4,257 of 5,353
It turns out it's not that simple. Here's a quote from the R-27HE manual:
" "2 - BNC", for the BNC coaxial digital input; (If update the EC firmware, the 2-BNC is for the external clock input .The external clock output impedance must be 75 ohms, the supported output level range is 0.7-3.0V and a 50-ohm BNC cable must be used.)"
p.s. I wrote to Kingwa, here's his reply:
" Dear Sir,
The R27HE default with 75 ohm socket for the clock input .
If your clock is 50 ohm, you can custom order the R27HE with 50 ohm socket .
The DI20HE default with 50 ohm socket so don't need custom order .
Kingwa
Oct 17, 2022 at 3:25 AM Post #4,258 of 5,353
Received the LHY OCK-1 today.
Set everything up.
I let Qobuz lapse. Just corrected that.
Is playing now. How long of a burn in is suggested?
Oct 17, 2022 at 3:28 AM Post #4,259 of 5,353
The Gustard C2 will be a while. Sent it to my brother in Australia.
So using a 75ohm Black Cat Silverstar in the interim.
At some stage will A/B with the OCK-1 and the DI-20HE internal clock.
Oct 17, 2022 at 2:50 PM Post #4,260 of 5,353
" Dear Sir,
Kingwa
Hard to understand what this means. And anyway, mixing and matching clock connectors is certainly not standard.
