gimmeheadroom
Not many impressions in this thread using a reclocker in combination with DI-20. Got Ideon 3R Master Time Black Star in the house few weeks ago and been testing it before DI-20 and straight with usb to dac. Still DI-20 in the mix holds it's magic.
However with 3R Master Time my preference is now serial mode instead of parallel that is normally in use. With parallel it seems to favor leading edge of notes slightly too much. Serial nails note sustain just right, perhaps the hardest trick to pull off for digital frontend vs vinyl.
Sorry to say for wallets there is noticeable difference in audio quality with 3R Master Time added in the audio chain. Overall openness of sound, improved soundstage depth, palpable more lifelike timbre, bass accuracy and authority (some serious wow moments especially with bass). I expect effects would be similar with Innuos Phoenix as well.
LPS powered JCAT USB XE card as source, T+A DAC 8 DSD with AES/EBU XLR input. Both USB connections without 5V power lines (data only). Tested with entry level Atlas USB cable without vibration pads so even more potential to be unleashed.
My setup is wired like this (3 paths, one instance of the components):
(1) PC -> USB -> DI-20HE -> I2S -> R8 mk2
(2) PC -> USB -> DI-20HE -> AES/EBU -> Mutec MC-3+ USB -> AES/EBU -> R8 mk2
(3) PC -> USB -> MC-3+ USB -> AES/EBU -> R8 mk2
So I can compare the system with or without the Mutec in it, and also with or without the DI-20HE in it. The best clarity, sparkle, and space seem to be when using path (2) above. However since I got the cable the guys here recommended, (1) does sound extremely good.
I haven't tried running the Mutec into the DI-20HE but that would be easy enough. I was interested in your comment about serial vs. parallel mode. I don't think I played around with that much. Thanks for your post.
