Jandu
- Aug 13, 2010
No, it cannot . Here I quote:Apologies for a potentially stupid question but can the ACSS spdif present in DI20 be somehow connected to BNC?
I happened to purchase a Hugo TT2 and I was wondering if there is any way to connect the DI-20 to it. The bloody thing doesn't have any inputs aside from USB, toslink and BNC
S/PDIF OUT ACSS :
Output using current transmission technology over coaxial (0.5VPP @ 75 Ohm).
This output applies the 2nd generation coaxial ACSS technology, which offers even further reduced signal degradation and better sound quality over a coaxial cable .
In theory, when the DI outputs the current coaxial signal to a DAC using a regular coaxial input, thus receiving the current through a 75Ohms resistor, the signal gets naturally converted to a 0.5VPP voltage coaxial signal. Therefore, most DAC can receive this signal and will benefit from this technology .
(Note that If the DAC's coaxial input has a built-in transformer, or if the input impedance is not 75 ohm, or if the input sensitivity is not 0.5VPP @ 75Ohm, the ACSS coaxial connection may not work properly ) .
