gaboo
- Apr 20, 2004
I'm not sure how to read this. For 16/44.1 that is an understatement. The resampling transforms the high frequency information in lower frequency distortion. The famous udial example shows this by exaggerating the high frequency component and the "aliens" can be heard.
For 16/48 & 16/44.1 there is also a driver problem with the Creative drivers, at least on my Audigy 2. I'm not sure exactly what happens, but I get "tubby" sound, and a collapsed soundstage. There is a 15 & 1/2 bits precision bug in the 10K2 DSP. It can be corrected with DSP snippet. The Kx drivers do this. I don't know about the Creative ones. When the bug is corrected, the 16/48 signal should pass unmolested. I didn't use the Kx drivers, so I cannot say if that's the only issue at 16/48. It is also possible that the Creative drivers themselves have a bug.
The situation is bit complicated to put in one sentence, so here is my A2 "effect" matrix:
bits/rate aliens tubby
16/44 yes yes
16/48 no yes
16/96 no no
24/44 yes no
24/48 no no
24/96 no no
I can ABX both the aliens and tubby effects (I get 7/7 on each). I prefer to use 24/48 on the Creative drivers, because it is easier on the CPU.
24/96 is not the only magic bullet, but it is one of them.
EDIT: I forgot to say this. The "tubby" effect is *much* worse than the "aliens" one. It is instantly obvious with almost any music, the "aliens" require special samples to be heard well.
Yeah, it looks like anyone buying the Audigy 4 will still need another card for music. On a side note: my TBSC works fine in the same box with the 1212m, but it causes instant BSOD on boot on the box with A2. I don't even get to install the drivers. If anyone here still believes the EMU drivers are on the same level with the Creative consumer one's, my answer is NOT in my box.
EDIT: I forgot to say this. The "tubby" effect is *much* worse than the "aliens" one. It is instantly obvious with almost any music, the "aliens" require special samples to heard well.
Originally Posted by Eagle_Driver This assumes that you're using a 16/44.1 audio file and having the Audigy resample that to 16/48. And sure, it doesn't do that resampling right. And even 16/48 files that aren't resampled will sound rather mediocre on the Audigys due to the fact that they roll off the highs quite noticeably. |
16/44 yes yes
16/48 no yes
16/96 no no
24/44 yes no
24/48 no no
24/96 no no
The result? The Audigy2's only sound good with native 24/96 audio files (or lesser files resampled in software to 24/96) - and only if all DSP effects (EQ, EAX, speaker positioning) are disabled. |
The AV-710 may use 24/96 - but only when used in stereo-only mode. If you have a 4.1, 5.1 or 7.1 setup, then you'll be limited to 16/48 maximum with that card. If anything, the DAC used for multichannel mode is even worse than the one on the Audigys. Thus, if you want full 24/96 support in multichannel mode, then you'll have to spend more money. Oh, by the way, it's very disappointing that the new Audigy4 Pro still lacks native hardware support for 16/44.1. 16/44.1 files still get resampled to 16/48 in hardware. And you'll still have to spring for the most expensive version of that card just to get full ASIO 2.0 support at 24/96; otherwise, cheaper versions of that card lack full ASIO 2.0 compliance by supporting ASIO output only at 16/48. |
