Kikomo9610
will @Audeze be fixing the cracking and popping sound when connected to pc?
I like the RoundandMuscular EQ preset or Flat for most of my music. Warm just dipped the highs down a bit too much for my liking.
I've read several times about EQ presets provided by Audeze, but don't see anything on the Penrose site. Where can these be found?
This is required feature for Xbox compatibility and was the reason why the Xbox units got shipped later. Initially we treated the Dongle like an external amp. It would always register as an audio device irrespective of the headphone being on/off. So when a user who uses the dongle with a console, turns off the headset, because they want to use their speakers, this feature is extremely useful.
So we also implemented this in the PS version.
Just trying to figure out if it would even be possible for Xbox or ps5 to make it not work thru the dongles. Dont understand why someone would write that if there isn't some way.No.There is a lot of speculation here. We do not plan to remove any compatibility intentionally.
Also having frequent popping and crackling, it's driving me insane !
I'm plugged into a USB 2.0 port directly in my motherboard, going to get a USB 2.0 extension cable to see if that helps
Penrose X btw
Hi @Audeze. I created an account here to give my vote to swapping the game/chat mix wheel back to how you had it in beta.
I bought the Penrose X and love them. I have a question if someone knows the answer -
As an iPhone user I won’t be able to use my phone to swap presets etc, with the upcoming update allowing wireless connection to Windows does it mean that while connected to my console I will be able to connect to my PC at the same time so I can try out presets in real-time?
Thanks,
@Audeze can we add functionality for lowering and raising sidetone audio levels in the app. I can hardly hear myself at the current audio level. My wife keeps popping into my room telling me to keep my voice down!
I agree! I can hardly hear myself at the current level, and if I bring the mic closer to my mouth to actually hear sidetone the mic starts picking up my breathing.@Audeze can we add functionality for lowering and raising sidetone audio levels in the app. I can hardly hear myself at the current audio level. My wife keeps popping into my room telling me to keep my voice down!
@ Audeze, a couple of things I think are fair to point out here: Primary Points on Chat Mix functionOur original design had the chat mix as the primary and volume gain as click+ rotate. In our beta testing everyone complained and we swapped it. Now it seems everyone wants it the other way. Maybe we should do a poll before changing them back again.
- If you read through this entire forum / posts, it's easy to see that this is by far the most requested feature / change.
- If we are all being honest..., this headset "Penrose X" is / was marketed as primarily for Xbox consoles (really next gen Series X & Series S)
- You really can't find a console (Xbox) headset that doesn't have this feature (chat mix as the primary) (Astro, Steel Series, Turtle Beach, LucidSound, HyperX, and so on...)
- The ability to adjusts this, is something that is constantly used by console (Xbox) gamers, as others have noted.
- It's far more intuitive and user friendly to have chat mix as the main wheel function
Other Points of Consideration:
- Due to the late release / shipping date of the Penrose X....., and limited supply of next Gen consoles....
- More than likely most beta testers weren't using this headset on the newest consoles.
- Also, the beta testers were probably a much smaller / limited pool of people
- Now that a lot more people have, and are using this headset "Penrose X" with next gen consoles...
- There is overwhelming demand to have the chat mix as the main wheel function.., as noted in this forum
Other Request / Features, for consideration (As others have requested):
- More volume steps, the jump in volume between clicks is too big.
- Battery indicator when in Bluetooth
- Ability to name Presets
- Way to quickly swap to different presets via the headset, not the app. Can this currently be done?
- Functionality for lowering and raising side tone audio levels (Should be adjustable and not just on or off.)
- Official Audeze swappable earpad options (like the Gel filled Mobius ones.., Can't get these in the US currently)
Being Completely Honest:
- Audio / Soundstage on the Penrose X = Amazing / very impressive. Love it.
- User Friendly Controls via Headset and App = Room for improvement
- Comfort = Not that great, need more earpad options
My Hopes:
- The headset controls / and app options = Become better with updates
- Comfort = Additional options are made available to provide more comfort to some users
I'm just respectfully asking that Audeze takes these items into consideration. Thanks.
