Thank you for your feedback. We understand it falls short of your expectations. Some of it firmware related and fixable. Some choices like headband is not.
But we do plan to adding features and improving it.
The clamping force can be improved by stretching them out over something but that only fixes it partially.
This is somewhat surprising – Mobius and Penrose have the same clamping force – and both headbands
willstretch over time (or use the “pillow method” proposed by another Head-Fi’er). We’ve sold almost 100K units over the past few years, and we haven’t received any major long-term complaints on this.
I'm not sure why they went with this design. The penrose and mobius look different from other Audeze products. There's a reason almost all sennheisers and beyerdynamics for example look the same. They know what works and they stick to it.
With Mobius and also Penrose, we had to add additional items (Batteries, Accelerometer/Gyro incase of Mobius, dual antennas for Penrose) etc. We also had to go with closedback and make sure the weight of the Planar drivers do not make it very heavy. So this was a choice that was influenced by making closed planars as well as making them efficient.
The scroll wheels for volume don't have enough granularity. Also, does anyone use the scroll wheel for your voice?
Granularity - We plan to have finer adjustments with firmware upgrades in future. The mic volume is intentional. People use this because somene on the other side says, the volume is too low.
Audeze HQ Doesn't work unless you connect through USB. To update the firmware you have to download a new app version, really?
Also, no way to see battery status, anywhere. Why is this not a thing in the app?
The App doesnt have to be updated to update the firmware. Unless we add new features to the app (which is also planned), you do not need to download the app again. Firmware updates shows up when we update the firmware in the cloud.
Battery status will be in the next version of app.
The 2.4Ghz wireless connectivity.
Bluetooth on the other hand has great range and I can go anywhere without it dropping. Through walls/ceilings etc. is not an issue and seems to work great.
There are only a couple of chipsets in the market. Almost every company making low latency wireless use the same chipsets. The choice is between lower latency, data rate and range.
There's 1 big issue imo with the sound, a very noticeable hiss.
The noise floor on Penrose with the current firmware (0.1.5) is very low. With the new firmware it is atleast 18 dB lower. Hae you turned off the side tone ?
As we mentioned earlier, we plan to add / modify a number of features over the next month. Android app to control the Penrose wirelessly is queued for release on the google app store for next week.
