funch
Yes, guitar does sound very good through them. Listening to some Acoustic Alchemy atm. Very clear, airy and punchy.
Thanks. Out of curiosity, I assume you played it at the same volume as you played it on the Iphone right? Just want to make sure we're not conflating volume/power. I'll get an amp and see how that works.
By the way, I just saw that Tyll from innerfidelity seems to have given the LCD XCs a bad review. But he also strongly dislikes the Shure full sized line as well . . .
http://www.innerfidelity.com/content/innerfidelity-february-2014-update
Audeze LCD-XC - Measurements show some unevenness through the mid-range and a bit too excessive spike on the leading edge of square waves. Brief listening has me thinking they're a bit rough sounding and uneven...review uncertain as yet.
Tyll dislikes most everything that has even the slightest hint of treble...so I'm not surprised he panned them.
600ohm headphones are often far easier to drive than current-hungry orthos. There's no MP3 player on the market that'll drive the XC to its full potential. I doubt whether you're even hearing a fraction of what they can do. You need a half-decent desktop setup or at the very least a very good portable amp to get the best out of these. Even a budget amp like the Schiit Asgard 2 would improve the sound drastically.
Being compatible with portable devices doesn't mean they'll sound good out of them. Mine sound awful out of my MP3 player or laptop.
I noticed that Tyll's innerfidelity website had two reading charts for the LCD XCs, (sample 1 and sample 2) which were quite different, perhaps suggesting that the LCD XCs change by a nontrivial amount as they burn in from use.
It suggests no such thing. It is simply sample to sample variation.
Do you have any other information on the two readings? The raw frequency response readings are 5db higher in numerous places on the second reading.
