AUDEZE LCD XC
- Thread starter SHAHZADA123
- Tags
- audeze-lcd-xc
abvolt
Beauty with quality of build and sound you're going to love them..enjoy
Yes the build quality is the absolute best that I've ever come across in headphones. I added 6db under 100hz and they sound heavenly.Beauty with quality of build and sound you're going to love them..enjoy
I have to say they sound pretty darn nice. I'll have to spend more time with them, but with both the 888 and hp8 they sound fantastic. And no sound leakage while wife slept next to me last night! Mission accomplished.
Hey guys, what cable do you recommend for the xc to get some length. The stock is too short. No esoteric ridiculous priced suggestions please.
jimbob54
- Mar 12, 2013
Single ended or balanced? Personally I'd get an extension, bought or custom made from eBay. Get a couple of feet longer than you need for the XC and it should do for any other new 'phone purchases in the future.
PinoNL
- Jun 1, 2015
Or you can check out Forza Audio Works
I'm good with SE. Thank you.Single ended or balanced? Personally I'd get an extension, bought or custom made from eBay. Get a couple of feet longer than you need for the XC and it should do for any other new 'phone purchases in the future.
Lebber67
XC needs balanced for the high in/out.
I,m using the balanced on my Questyle and the output doubles, makes a clear difference for me.
All my stuff is SE except the new 888 amp. I'm good with SE.
jimbob54
- Mar 12, 2013
I have a couple of the grado extension leads couple of meters long, robust. Reckon you can pick them up for not a lot. Interestingly, think audeze use same company as grado for there 1/4 inch to 1/8 inch adaptersI'm good with SE. Thank you.
Cool thx.I have a couple of the grado extension leads couple of meters long, robust. Reckon you can pick them up for not a lot. Interestingly, think audeze use same company as grado for there 1/4 inch to 1/8 inch adapters
