doughead
- Sep 2, 2015
Thought I'd share my thoughts after burning-in my LCD-XC for more than 300 hours..
To be honest, I am (still) puzzled by the many differing views on the LCD-XC sound quality, from web reviewers as well as fellow owners. I've seen it rated as having "bass to die for" as well as being bass-light (not for rocking), and the treble was often mentioned as being smooth but I've also seen others saying they are bright. Well, after listening for myself (after extensive burn-in, whether one believe in its merits), I'd have to say that they are definitely not bass light. I think they have a very rich and weighty bass (when the music has it) and the bass has very good texturing and definition ("planar bass" I guess). But there is also no denying that the upper-mid (or lower treble) has a "squawky" character which makes female vocals and horns sound bright especially when played at high volumes. Why did Audeze choose to tune it that way stumps me! Perhaps they were trying to "improve" upon the LCD-2's rolled-off treble and narrow soundstage on a new LCD series headphone but I would think they have overdone it. Or perhaps its just a technical limitation due to its closed-back design and the compromises which the engineers have to make...
The irony is that I started off with the EL-8s and its for brightness reasons that I chose to sell it eventually. I wanted the LCD-2s but couldn't accept its "closed-in" sound and inherent darkness, although I'd have to say its only apparent for certain types of music/recordings. Then I was recommended the LCD-XC for its "great bass as well as being spacious sounding". Its closed-back design as well as its astonishingly easy-to-drive low impendence was the icing on the cake! Would I sell the LCD-XC for its brightness again? No, it has mellowed somewhat after extended burn-in and I found that it only occurs with certain recordings and is not an issue unless I'm playing at higher than normal volumes. Whatever cons it has (brightness + weight), the pros certainly outweigh them - very deep and textured/defined weighty bass, very spacious sounding (for a closed-back) and a full-bodied and meaty sound with excellent clarity, airiness and imaging (for a headphone). I would say the sound quality is so good that I consider it as my "second hifi setup" (to my home setup) and a portable one to boot!
The most surprising thing about its great sound quality is that I'm not even using high-end source components - a Hifiman HM-650 DAP and a Cayin C-5 portable headphone amp. In fact, I am amazed that I'm listening at '2.5' volume (max is 9!) on my Cayin amp and there are tons of headroom to spare! If I were to upgrade anything, it would be the amp and those that got my attention is the Triad Audio L3 (yes I'm a basshead and I prefer a portable amp), the Audeze Deckard (same family) or the Audio-Gd NFB-1 (I really want to go balanced!). Any thoughts on these 3 amps will be appreciated but I have to say I'm in no hurry to upgrade as the Cayin is doing superbly well for a low-cost headphone amp and a portable one at that.
