Mojo777
- Jan 28, 2007
Thanks. I am assuming you are running balanced xlr with high gain? They are pretty easy to drive but at normal gain I have to crank the volume.
For a good comparison between the XC and Alpha Prime check out the comments section to Mike Mercer's excellent Alpha Prime review from www.headphone.guru where he compares the two headphones. http://headphone.guru/mr-speakers-alpha-prime-the-alpha-evolves/
Do you need closed cans? Or can you listen to open cans? If you don't need the isolation, I personally would be looking at the X and the 3.
Maybe an open box X and a pair of the alpha dogs or el-8.
I can indeed use open cans. Just always had closed.
Not much noise in my office - just air conditioner. And I have a closed pair of Mad Dog Pro's. So, I could do that. Hadn't really thought of that.
I assume the 3 would be considerably better than the X?
Do they pair well with the Ragnarok?
How might I find open box cans?
(I will go check out the LCD-3 forum here as well.)
This is why I ended up buying the XC. No need for two cans. If I am getting, imo, 97-99% of the best of both worlds then just one set will do for me.
Had an interesting afternoon comparing the XC's and the 3's. Although the bass was richer and with a bit more impact with the XC's (which I own and love), I prefered the 3's overall due to richer mids. Vocals seemed more fleshed out with the 3's. Vocals with the XC's were still good, but seemed relatively thinner and brighter. The isolation offered by the closed XC's was great, however, and may be better for my somewhat loud office. Ah, wouldn't it be great to be able to have both!
Just a couple opinions...I own the X and XC and greatly prefer the X side-by-side. However, the XC sound good and they're closed. In an office environment, if there are other people around then you need the closed HP. With more time and maybe a good amp (the 3's impedance is about 110 ohms, while the XC impedance is 20 ohms), I think you'll see more of a difference between those cans. So just flex the wallet and pick up the 3 for home use, and the XC for the office. You'll make a lot of new friends .
Cheers -
RCBinTN
