thefitz
- May 22, 2015
So you also have the non leather pads for the X? Why have you replaced the standard pads?
I also find that the X sounds somewhat as a LCD 3 with a quarter hd800. But the hd800 itself is not my top pick. Overemphatized detail and the mids are not transparent. If you want a dynamic with mids similarly fluid like with the LCD range, listen to the Shure 1840. Off course not as transparent and fluid as the LCD's but much better than the hd 800.
But if the 2016 LCD XC is brighter than the X, then that's my headphone. Tomorrow I'm going to try to listen to the XC if that's possible.
Mine came with vegans and I think they're perfect headphones. I'm anticipating the pads have something to do with it, so I want to replicate it on the XC.
