ClintonL
- Mar 15, 2012
Awesome, also wondering if these will run alright on a cambridge dac magic plus amp? I heard they don't require much juice. Also have an audiogd nfb10-se too.
I can't fully concur. With LCD-X, I definitely prefer SE outputs over balanced from my Taurus II (Audeze original cables). Sound more dynamic, punchier, better transients. May depend on the output impedance of an amp, LCD-X being a 22 Ohm headphone. Taurus has cca cca 5 Ohm output impedance on balanced outputs which might not be sufficiently low for LCD-X. SE outputs are cca 1 Ohm and the ratio should be, as far as know,1:10 at least to ensure good control of the amp over the headphones. I am not an expert, I'd appreciate further comments.
Definitely worth using the balanced cable. When I got Schiit stack with balanced outs and the Audeze stock balanced cable for the LCD-X I heard one of the more notable differences in SQ that I've gotten so far.
Will do more listening to see if any differences.
Just getting around to buying the WA7 + tp..
Should I bother buying any of the upgrade tubes that Woo offers on their website? So far I have just the Sylvania JAN 5814 in mind. I'd like to have tubes that'll give me a feel for how different they can make the sound.. Any suggestions for start-out tubes?
And just to clarify, I only really need a pair of 2 tubes for in the power supply, not 4? (I could, but it wouldn't improve the sound much. Am I understanding that correctly?)
I don't have the tube power supply yet, so I can't speak to which tubes are best for it, but the Electro-Harmonix Gold Pin tubes in the amp definitely make a difference. Keep in mind that the amp and the power supply do not use the same tubes, as your wording implied. I've heard that they might be discontinued, so in case that's true, I would probably buy them as soon as possible. You can always resell them if you don't like them.
At a guess I would say changing all tubes would provide the best sound from the amp.
The upgrade amp tubes mainly increase extension a bit in both highs and lows.
Woo is not the best place for tubes. He pushes average tubes as the best and demands top $$'s for them. Go to the WA7 thread and see what others say. Then go hunting for them.
Also, with the WA7, make sure you run the amp with the low impedance setting with the LCD-X (go figure, they are low impedance headphones). The high impedance setting won't sound awful, but it does cause the highs to get a bit of an unnatural boost. A friend of mine who has produced a few small records, but who is not really an audiophile noticed it when I forgot to change the impedance after switching from my HD 700's.
After testing several types of tubes (Mullard, RCA, Sovtek, CBS, Electro Harmonix) both in the amp and the power supply, the best combination I have found is the gold pin Electro Harmonix upgrades from Woo combined with Electro Harmonix tubes in the power supply.
Go to the lyr tube rolling thread. Should be lots of impressions with the X
I know that these thoughts about tubes are in regard to the WA7 with the LCD-X's, but I'm interested if anyone has recommendations for tubes to explore with a Gumby/Mjolnir 2/LCD-X setup.
hey everyone, i already sent a ticket to audeze but my right driver is making a soft clicking noise even when there is nothing playing. when plugging my hd598 into my centrance which is what my lcd x is in there is no popping, any causes of this?
sooooo, is it due to something in the driver, I haven't tried the other cable yet.
