All Day Breakfast
I hope someone can give me some DAP advice. I’ve had the LCDi4 for a few years and use them exclusively with the cipher cable and the Audeze EQ programme on my iPhone. I really enjoy this setup but I keep wondering how the lcdi4 would sound with a more powerful amp and 10 band parametric equaliser to mimic Audeze’s Reveal plugin and as far as I understand there are no parametric eq apps that work on iOS. I‘ve read up a bit on DAPs but I haven’t been able to clarify which ones for certain have parametric eq functions, whether all DAP parametric eq are of the same quality (I’ve come across some comments about A&K peq being broken?) and whether or not those parametric equalisers work with the downloaded Qobuz app (my only music source) whether in APK form or from the PlayStore depending on the DAP.. Although cost isn’t a problem would I actually hear a significant improvement with a quality DAP and my LCDi4? Is there a way to simply connect a DAP to my Hugo2 and would the parametric equaliser still work with that setup? I have no other use for a DAP other than use at home to eq my LCDi4 with a more powerful DAC/AMP than the Cipher cable so the improvement would have to be worth it over my current setup. I’ve looked into Roon and Audirvana to run on my desktop but that solution don’t interest me as I’d need to get a 2go to work with my Hugo2 and the 2go seems to have its challenges. I have considered getting a MacBook Air to run Roon to connect via usb to the Hugo2 as an alternative to a DAP but a DAP seems like the more elegant solution if it would deliver a significant improvement. Any thoughts appreciated.
