VladislavLysov
Hi there. Finally go with lcd-4z. Can somebody describe how to check if the headphones with updated earpads or it's old revision?
Still don't get them, so can't say for now. They are b-stock from official audeze dealer and they have only stock images. I supposed if it's b-stock and factory sealed, so I suppose it's this model year. Do you know in which year the pads were replaced?Send a picture
Thanks!Just call them and ask for the new pads before they ship
Reverse/flip your cables (use right cable on left driver and vice versa), and see if the imbalance switches over. If it does, there's something wrong with the cable.Has anyone else felt like there might be a slight volume imbalance in one ear over the other?
In my case, it seems like the right earcup is a bit louder than the other as my other headphones/speakers sound perfectly balanced.
Does anyone else has this issue? What test can I do to make sure they are working fine?
Stay updated on Audeze at their sponsor profile on Head-Fi.
I did and the vocals switched over to the left side.Reverse/flip your cables (use right cable on left driver and vice versa), and see if the imbalance switches over. If it does, there's something wrong with the cable.
It can also be a connector issue, or it can be an actual driver imbalance.
Contact us at support@audeze.com so we can help you further.
Cable and headphones seem fine (12 and 13 ohm resistance).
This only happens with vocals and I'm guessing because they're so good at imaging, I get this imbalance not because there is something wrong with the headphones or cable but most likely because other headphones/speakers aren't as accurate.
Wow, thanks! Will try to do that. I heard that regular LCD-4 doesn't need to warm up, but I'm totally fine with it as long as I don't need to spend $ on new amp =)Break in at least 100 hours for sure and they will sound amazing.
Hi all! Just got my sealed box LCD-4z. From the box they were not very impressive to compare with my current HD800s. But looks like day-to-day warmup helps. Is it true that they should be warm-up and if yes - how long? I know that some headphones don't need it, but in LCD-4z I really hear the difference between day 1 and after few days.
