thefitz
- May 22, 2015
Yeah I saw that as I was re-reading them - crazy times. Sounds like all issues got sorted out.Crazily enough, the LCD-4 was gimped too
"After Bob's experiments, Focal asked if InnerFidelity could measure the Utopias used in the shootout to see if they were defective in some way. His evaluations also confused me because I thought the Focals clearly superior. I had Bob send me the headphones used in his shootout for measurements. Turns out, the pair used in my review and his shootout indeed did measure differently and in such a way that our disparate findings were understandable. Bob wrote about it in his Smoking Gun article.
I then had to find out which Utopia was representative of the currently produced product and measured numerous Utopias. I found that the pair I initially reviewed was not representative of current product; the pair used in Bob's evaluation was.
Additionally, it was found the LCD-4 Bob used in his efforts was faulty in one channel and the pair I reviewed had some modest tonal imbalances between channels. I think this likely added some confusion in evaluations."
https://web.archive.org/web/2019051...ame-adjustments-focal-utopia-and-audeze-lcd-4
FWIW, I did a frequency sweep of my pair just now, and I got the following:
-A bit of a roll-up from 20-40Hz
-Basically dead flat until about 1200Hz
-A little hotter from 1200-1600Hz, not the honk I remember
-Flat from there to about 2700Hz
-A lower level from 2700Hz-6000Hz
-A couple of very short nodes from 6000Hz-8000Hz (common)
-Flat but a little sizzly from 10kHz-14kHz
-SILENCE FROM THERE BOYS
i.e. no 4kHz node for me! But the whole treble section was lower overall until 10kHz
Using my Chord Hugo as a DAC was surprisingly satisfying - I think some of the distinctness of the Hugo complement the distinctness of the LCD-4. The overall size and staging of the image wasn't quite up there with the Yggy, but the sound signature was clearer overall.My I ask what Dac and amp combo and source your using? I had the same issue of EQing the LCD 4 and loving some parts of the lcd 4 FR while not liking others. I am somewhat of a bass head so I'd probably prefer the lcd 4 to the 5s having not heard the 5's. I upgraded my source to an Audio gd di 20 with ocxo, got the 2021 pads and added a powerplant and while it hasnt fixed absolutely everything, it does fix many or most things like lifting the veil in return giving the lcd 4 a very balanced sound and better image and sound stage. YMMV. It is a bit unfortunate that almost every high end headphone needs a good backbone to make them perform the way they are intended to. After these upgrades and a bit of tweaking in terms of EQ, Im more than satisfied.
