Check in the manual (page 22 onward I guess). Parametric EQ, need to manually set the bands. AutoEQ oratory1990 data is the most harman, so try that first. The problem is you only have 5 bands in the RME PEQ. So you are better off using your PC with a PEQ like Equalizer APO + PEACE GUI for Windows or something else for other OS.Is anyone using the RME ADI-2 with the LCD2C? If so, are you EQ'ing them? Is there a common agreed EQ for these 2 components that helps correct the LCD2C? Thanks.
If you do use RME PEQ, try this sets of filters for the presence region:
oratory1990:
Filter 4: ON PK Fc 2761 Hz Gain -2.9 dB Q 4.10
Filter 5: ON PK Fc 3708 Hz Gain 7.0 dB Q 1.65
Filter 6: ON PK Fc 4689 Hz Gain 1.6 dB Q 4.23
Filter 7: ON PK Fc 5500 Hz Gain 0.3 dB Q 2.61
Filter 8: ON PK Fc 6128 Hz Gain -4.4 dB Q 3.24
InnerFidelity:
Filter 2: ON PK Fc 757 Hz Gain -2.6 dB Q 0.21
Filter 3: ON PK Fc 3913 Hz Gain 7.2 dB Q 1.67
Filter 4: ON PK Fc 5913 Hz Gain -5.7 dB Q 4.31
Filter 5: ON PK Fc 8753 Hz Gain 4.0 dB Q 1.49
PEQ is a game changer. Especially when we have the AutoEQ data base ready to use, just find your headphone and load the bands/filters. Enjoy!
