boberang
- Nov 14, 2003
I am responsible for the DSP behind cipher cable. The Graphic EQ used in the app will not guarantee perfectly flat response if you reduce all bands by say 5dB and may not be an optimal solution if you want to get the best out of the Cipher cable.
Three questions for you after looking at the 10 band Graphic EQ app in the app store. It has two preset buttons and a reset.
1) As you adjust those sliders under one of the presets the actual settings are sent to the iSine 20 (or 10) and saved in memory immediately, and if you tap on a different preset then that sound profile is loaded right away?
2) And if you select the Reset button it goes back to the Cipher cable as shipped, so it has the PEQ profile you developed for it straight out of the box?
3) How likely is Audeze to offer plugins for virtual rooms in this app, or would that be a different app? Or is the answer it depends on sales numbers?
