If your like me and don't want to spend crazy money on cables, I recently got a Penon CS918 cable that sells for $55 on eBay four $38 because it was slightly used and had a but it now if $45 and eBay had a 15% off coupon code.
Effect Audio and PlusSound also make cables that will work with iSINE's notched .78 mm connector, available balanced or unbalanced at your preference. Expect to spend $150 for either but also expect quality connectors/jackets/ysplits/etc.
Just picked up the 10's on the classifieds, outstanding first impression w/ cipher. Keen to see what magic we can do to with EQ when the Mojo arrives as well..
Only issue though: the 2 pin connectors are quite loose - the left in particular has fallen out while listening on several occasions already. Is a non-Audeze cable the answer, or maybe even the V2 cipher + a plussound cable down the track?
