Audeze EL-8: The EL-8 is a must-hear at CES 2015
Dec 13, 2015 at 2:36 PM Post #5,641 of 6,486
 Prepare for eargasm if you get a good pair-they're special..........you'll be surprised that the treble doesn't need to be "tamed" at all
Yes, I'm praying to the HP gods!
I saw your (impressive) gear list: how do you like the Deckard with the EL8s? and with HPs in general?
(and any particular reason you chose the Ether Cs over the Foster Th900s?)
Dec 13, 2015 at 4:57 PM Post #5,643 of 6,486
 The Deckard is a very underrated amp imo-drives just about anything and it's great with the EL-8. I bought it after hearing it at Can Jam London.
I got Ether C's because I already had Th600's that I was pretty satisfied with and I pretty much preferred them to the TH900..........TH900 had more bass and more treble, but in the end I felt the 600 was better balanced, even though it had less detail. If I had to make a choice between Ether C and TH900 though, I'd take the 900 because Ether C doesn't have any weight in the bass. More clarity and better soundstage than the TH900 although they are very close in both departments.
Dec 13, 2015 at 5:22 PM Post #5,644 of 6,486
Using sine generator I can hear a small dip @ 6300hz and a bigger one at 7000hz. That could just be my hearing and not the headphones, but other than that they're pretty flat from what I can tell (and respond well to EQ).
Dec 13, 2015 at 5:55 PM Post #5,645 of 6,486
Good to hear some feedback re the Deckard. I've never actually heard anyone reference it in the forums.
Then Audeze' next amp produced was/is the King.
Hhhmmmm. $700 (Deckard) vs $4000 (King).
I've been thinking that the Deckard sales seemed low b/c they
didn't cost enough to get the attention of Audeze HP owners!
Maybe a $4000 amp will get their/our/my attention!?!?
Dec 13, 2015 at 5:57 PM Post #5,646 of 6,486
Using sine generator I can hear a small dip @ 6300hz and a bigger one at 7000hz. That could just be my hearing and not the headphones, but other than that they're pretty flat from what I can tell (and respond well to EQ). :beerchug:
Are you referring to Open or Closed EL-8s?
Dec 13, 2015 at 6:28 PM Post #5,647 of 6,486
Closed. That's also just the rough area (it's not EXACTLY at those frequencies, just around them).
Dec 14, 2015 at 4:52 PM Post #5,648 of 6,486
I can hear them in the opens as well. But it's not anything I'd have noticed in any music, so I'm not stressing over it.
Dec 16, 2015 at 12:20 AM Post #5,650 of 6,486
(posting this in all the EL-8 threads)
I need a Balanced EL-8 cable that terminates in 4-pin XLR. So far these are the only two options I've figured out:
http://www.c3audio.com/store/p99/Audeze_EL-8_Headphone_Cable_--_Canare.html
or
https://www.audeze.com/products/accessories/el-8-balanced-cable-astell-kern
http://www.norneaudio.com/litzheim/Norne-Hypershort-Eidolic-Astell-Kern-ak240-ak380-ak120-ak-240-380-120-adapter
The first option comes out to be $100 and the second $125. Are there any cheaper cables or adapters out there or are these my only two choices?
If these are my only two choices, which do you think is the best route? The adapter I may find a use for in the future, but the custom cable may perform better?
Dec 16, 2015 at 12:47 AM Post #5,651 of 6,486
This is 100% my personal preference, but I would go the solid cable over cable+adapter just because I like having has few "connector points" as possible. Less stuff that can loosen over time. I've had too many cable adapters that started to cut out for whatever reason.
Dec 16, 2015 at 2:20 AM Post #5,652 of 6,486
BTW anyone have any idea what a decent cheap-ish IEM would be that has a similar sound signature to these? Just want something for in the gym so it doesn't need to be amazing, just in the ballpark.
Dec 16, 2015 at 4:52 AM Post #5,653 of 6,486
or
Have you heard plusSound audio cables? I've had multiple cables from them and it is awesome! they had plenty of cable options -wires, connectors, styles and colors. Totally recommended..check it out! http://www.plussoundaudio.com/
Dec 16, 2015 at 8:47 AM Post #5,654 of 6,486
get the MONK ...see my signature..it is a earbud.
