Dulalala
- Jun 18, 2016
https://www.amazon.de/dp/B00PEUBIKM/ref=cm_sw_r_cp_apa_rAjfzbS2SX5CE
These? Yeah i had a look at them earlier, really liked em but shame they are kind of over my budget. Also looked up the shures i like everything, but is that plastic sturdy enough? And if i go for shures should i get HM5 earpads? Or which
Well in my experience, the plastic will last, though I would be a little careful with the pleather. If you don't take care of it, it can start to peel. I personally used the HM5 earpads too, they're great but they will make them leak a bit more sound. It's not a drastic amount but anyone sitting directly next to you maybe able to hear your music if you play it too loudly.
