BigTerminator
- Apr 9, 2013
For a 2.1 setup use 2 channels for audio and 5.1 for analog out. The whole goal is for the same stereo sound, just with the subwoofer added.
You can still use the surround sound DSP's but I would urge against it as you want the sound to be pure. I game with my 2.1 setup without any DSP's and can locate all the enemies, even behind me. If it makes it better than use it but I personally don't.
You can use 8 channels but it might mess with your music and regular sources that are stereo.
The honest truth, if you have your speakers positioned correctly with your listening position, the soundstage and imaging should be good enough for gaming without the use of DSP's to give you fake surround sound. I would say run it in Hifi mode (unless you want the eq), 2 channel in, 5.1 channel out. Adjust your speakers to give you accurate imaging.
The DSP's make the sound from my speakers unnatural. For headphones it helped, but for speakers it ruined it.
It will do 5.1 if you plug in all the speakers via RCA. You do not have to run it in 7.1 mode.
I see, but will it have enough power to drive 5.1 regular speakers that are not powered? (satellite + sub speakers).
Thanks
It sounds identical. Check the volume mixer. Also when I switch channels sometimes the audio track has to be refreshed otherwise it won't work. If you are still getting loud enough volumes then what is the big deal. Is your setup generally working with the sub?
When I first got my H6 to use with my sub, some games had no dialogue. It did this because I had no center channel, so I was missing all that information. When I installed the drivers and disabled upmixing I could hear the game normally. You can play with stereo output and 5.1 to see if you are missing any information. Usually you can tell if the movie or video game is trying to run a 5.1 signal. It will sound quieter and dialogue will be axed away. Keep the card in 2 channel mode, keep the volume at 76 unless you NEED the extra volume, 76 is a 0db signal which is what you want.
