Asus Essence One Headphone Amp/DAC (CeBIT 2011)
Feb 13, 2013 at 5:07 AM Post #1,441 of 3,573
Since we are on the subject of OPA2132 my opamps finally arrived, they must of gotten or something, friend sent them a month ago.
Anyhow I got
2x OPA2107
4x OPA2132
2x LM4562
4x LME49722
The OPA2132, LM4562 and LME49722 are a surface mount package on DIP adapters, I'm just a bit unsure about the OPA2132U what does the U stand for and are they safe to use? Although I have been using them in this combination of 4 OPA2132 I/V and 2 LM4562 they seem to be working fine just thought I check with you guys though
Coming from the standard E1 edition I'm quite surprised at the vast improvement in SQ, I was thinking it would improve a little, not this much,  I can never go back to flabby bass no detail NE5532.  The detail in this op combo is just amazing so articulate with a tighter denser bass, however it is a tad bright not painfully like having ice picks in your ears, just a little unnatural to my ears through the Fostex TH900, not that the TH900s are natural sounding, far from it, it's brighter then the NE5523. Also asus say this opamp combo is "slightly cool" I didn't at all find them less warm, but could be on other HP's like the HD800.
Overall I'm very happy with the SQ, and now want to tryout the muses, rather then buying a better DAC :)
Cheers,
~Steve
I have some 2132-s, i´m going to try them in the buffer with ad797 in i/v. I also had your op combination however i found the 2107 in i/v and 2132 in lpf better. It was a little less bright and more mid focused. Right now i am still trying to find a good neutral combination with the ad797 in lpf. The op-s i have right now are:
5xad797
8xopa2107
8xopa2132
7xlme49720ha
6xlme49720na
3xlme4562
6xne5532
6xopa1612
4xlme49860
I tested a lot of combinations with these but still haven´t found a truly neutral and good sounding combination.
lme49990 and opa827 are coming soon. I also have some lme49710-s but i am waiting if i will use 49720 in the one before i invest in adapters for them. I am guessing the 49710 has the same sound character as the 49720 just with better sound.
Feb 13, 2013 at 6:47 AM Post #1,442 of 3,573
5xad797
8xopa2107
8xopa2132
7xlme49720ha
6xlme49720na
3xlme4562
6xne5532
6xopa1612
4xlme49860
Cool Rav, good to know after further testing I will more then likely buy some more opamps and keep the 2107 in mind as i've only got 2 of them at the mo. So out of all the combinations you could have with those op's what is your favorite combo, and what HP you use if you don't mind me asking?
Can't find much info on the LME49722 is this just a renamed LME49720 that I read somewhere early today, any info would be appreciated if anyone knows?
Cheers,
~Steve
Feb 13, 2013 at 9:03 AM Post #1,443 of 3,573
I also have to change the gain, and will take some pictures
sweeet
Feb 13, 2013 at 11:26 AM Post #1,444 of 3,573
Cheers,
~Steve
WIthout the ad797 the best combination i found was the 2107 in i/v, the 2132 in lpf and the 1612 in buffer. I am using the hd 650 as headphones but i also use them with speakers that are quite neutral and direct sounding so i can test the op-s with different sounding equipment.
Feb 13, 2013 at 1:43 PM Post #1,445 of 3,573
So far im using MUSES01's with NE5532 in buffer, and they sound prettttttty darrrrn gooooood.
Tim
Whatever combination I use, everytime I place the NE5532 in the buffer I get those piercing "sss" back.
I find the AD797's best in buffer.
I/V: NE5532 ; Buffer: AD797BR best combo for me so far. - good bass, relatively smooth highs (just a tad too bright sometimes)
Feb 13, 2013 at 1:47 PM Post #1,446 of 3,573
Guys, I can't find the gain switch!!!
Feb 13, 2013 at 1:52 PM Post #1,447 of 3,573
Iono, i 've always made my own.
You can try ebay. lol.
Tim
I found this (must have gotten it long time)
What do you think? A keeper?
Feb 13, 2013 at 2:00 PM Post #1,448 of 3,573
Hmm, it's not at the spot where we assumed it would be...
That coax cable looks good to me. However, you will just need an optical cable if you plan to connect your E1 to the ZxR, like I will.
Feb 13, 2013 at 2:07 PM Post #1,449 of 3,573
So whats happening???!! where is it?
I found this also:
Feb 13, 2013 at 2:09 PM Post #1,450 of 3,573
I don´t like the ne5532 because it always has a bass heavy and muddy character. The ad797 is much better in the i/v than the ne5532. Right now i am using the 49720ha in the lpf and the opa3132 and it sounds pretty good so far. The 2132 in the lpf doesn´t quite has the sound stage of the 49720 but with the 49720 the sound was too thin.
Feb 13, 2013 at 2:19 PM Post #1,451 of 3,573
Based on your pictures, i could not locate the gain switch.
Perhaps it's underneath the PCB.
Tim
Feb 13, 2013 at 2:20 PM Post #1,452 of 3,573
Tim
I suspected this, maybe later.
Feb 13, 2013 at 2:29 PM Post #1,455 of 3,573
But that sounds unlikely i don´t think asus would expect the customers to disassemble the dac just to set a gain switch.
Yes, i have doubts also.
ASUS needs to help us understand this.
I wonder whether or not it detects IEM's and adjusts the gain by itself. hm..
Tim
