I didn't bother with the dampers. Putting them on would also require gluing them to the plastic tube that extends from the BA driver. If you don't mind a slightly harsher sound in the treble (but more apparent resolution), then don't bother with the damper. Use a lower value in-line resistor to make up for the excess treble. It won't be as smooth, of course, but the result is still much better than stock.
This is what I've done: Taped all vents and done a smaller hole in the vents on the back. In addition I use a 50 ohm in-line resistor and Philips Fildelio S2 tips. The result is much more enjoyable (to me) than stock configuration. Mids are more forward and bass is less boomy
