When used as a usb dac, is there a setting to for the DAP not to draw power from the source ala Sony DAPs (enabling them to be used with iphones for example, as Apple Music is not supported)
Playing 24b/48k high res FLAC in a loop, using 2.5mm balanced output, average sensitivity/impedance IEMs, normal listening volume level with wifi/BT/EQ off, and display mostly off (just periodically checking the battery status) - 21hrs 45min playback with 1% remaining on SR25
You were trying to download this app from apkpure and side load it on SR15 and it doesn't work? while it works on SPK, considering all running the latest fw? Do you have a link to the app you are talking about? I can download and try it on SR25, to let you know if it works. Googling vlink bring up various apps.
No it wasn't a downloaded app. It was included in one of the firmware updates from AK. If it's not in the SR25 means AK probably didn't intend for the SR25 to support V-Link then...
That article mentions SR25 price to be $799 which is incorrect. SR25 price is the same as SR15, and listed on A&K site for $699.
Also, a bit puzzled reading that SR25 is brighter than SP2k, but I guess relative to different iems/headphones and depending on the tune we hear things differently.
