havagr8da
- Sep 5, 2009
I love Rock n Roll!!! Really really love it with Amazon Music HD on the SR25 with Thieaudio Legacy 3 iems. What a bargain!
Now I'll have to find a decent 1tb disk.
recommendation as to which output to use in lineout, 1v, 2v? And why?
Just a guess. Maybe isolating the metal plate from SR25's metal chassis (eg: pasting small bits of plastic tape between their contact surfaces) may improve signal strength. My thinking is this will reduce the grounding effect of SR25's chassis with the metal plate. It may not work at all, but it's also an easy test.I’m having some issues regarding WiFi.
Recently I acquired a case made for the SR25 by Dignis with stainless steel heat guard on the back, this one.
For some reason when I put the case on my Wifi bars drop to 0. Not sure if it’s the stainless steel that’s causing an issue with the signal.
I’ve tested this around three times so l believe this is the issue.
Tried the DAC setup on a Win10 machine, the volume in exclusive mode seemed OK.So I'm trying to use the SR25 as USB DAC, streaming Tidal to it via USB from my MacBook Pro, but I'm a little confused about a few things.
According to Tidal website, they recommend to enable "Use Exclusive Mode" when using external DAC. At least I think that's what it means here:
https://support.tidal.com/hc/en-us/articles/360005773698-Optimizing-HiFi
Sorry for telling the same story to anybody following the Senn H599 thread but I think this is relevant here as well. Today I received a balanced cable for my Sennheiser HD599. I ordered it from Aliexpress a few weeks ago after the good experience with Final E4000 iems and a balanced cable with the SR25. The Senn shines with my A & K SR25, truly excellent sound. The volume is of course a lot louder but, to my ears it also sounds better than the 3.5 unbalanced. I know this is a controversial subject. As to volume, what used to be 100 is now 85, but the quality of the sound has also changed.
i know quite well the sennheisers after intensive use the last months and I believe they sound better out of the balanced output. More detailed and better bass I would say. They already sounded amazing but now it is even better. Anyway, continue improving the experience with the SR25. This voyage of discovery of audio goodies is wonderful!
SO, my question is, what is the best settings to use from Tidal app when using SR25 as USB DAC to get best possible SQ? Spoiler alert, I've tried "Use Exclusive Mode", but for some reason, that kills the output volume so badly that I've got to go to 150 on the SR25 just to barely hear anything, and then I've got to unplug the USB cable and reboot the SR25 to restore normal listening with that "Use Exclusive Mode" disabled...
I could of course just use either the Tidal native or APK app on the SR25; but when I'm at my desk, using the Mac is a MUCH better experience to navigate Tidal, and the Mac gets a MUCH better WiFi signal for streaming...
What am I missing here?
But you don't need to use FAT32. I'm using with a 1 TB card exFAT without any problems.
Of course! The Senn cable is this https://www.aliexpress.com/item/32843066350.html?spm=a2g0s.9042311.0.0.3e1963c0UmKc2pLuis, thanks for sharing your experience with balanced cable! Mind letting us know who from/which cable you purchased for the Senn? and for the Final for that matter, thanks!
