AnalogEuphoria
Hello again after quite some time,
I am about to get Beyerdynamic dt 770 pro to pair with my SR 25.
The question is, which version should I get? 250 ohm or 80 ohm? Can SR25 drive 250 ohm version to its full potential?
And even if it does, what differences would they have, 80 and 250 ohm? I read about 80 ohms being less bright on treble att higher volumes which would be a good thing for this headphones considering the bright characteristic of its trebles.
Help please
I’d go with the 80hm for SE but the balanced out could absolutely work the the 250ohm you just need the 2.5mm cable.
