maico996
This is what I do in my truck and the sound is amazing. Highly recommend this over trying to use Bluetooth.Right, for that to work, the SR25 would have to support Android Auto, which it doesn’t today and I’d be surprised if it ever does.
If you want to use the SR25 as a source in your car, you can set it to Line Out and use a 3.5mm cable to connect it to the Aux In of your car. That way you’ll be using the SR25’s DAC stage, which is why you bought it, right?
Or, you could do what I did and forget about using the SR25 in the car, and just use your phone instead
