giangp1
I pay attention on it but nobody have. Hic hic!Hi!
Someone have the 1.20 or 1.31 firmware file?
Ty
Ty
Hi,
I bought the Se100 and realized it doesn't have Chinese language selection.
Would like to ask is it possible to have Chinese input (for song searching purpose)? For example, installing different keyboard?
Just download and install China firmware.
Thanks for the info. May I know where can I get the China firmware? And I just installed over existing firmware? Or needs to perform some other steps first?
Shutdown unit then press+hold vol+ vol- power untill "A" logo displayed then release holding after 2s.
There is Menu display then.
You need a usb/card with firmware file content
But I can not find anywhere to download firmware. Hic hic!
Just curious; how do you 'press and hold volume + -" when it is a volume knob and not a button?Shutdown unit then press+hold vol+ vol- power untill "A" logo displayed then release holding after 2s.
that is the skip and pause/play buttons, there is a volume wheel on the other side.
What is that? Not a button?
I was wrong. So sorry, hi hi!that is the skip and pause/play buttons, there is a volume wheel on the other side.
I use my SE100 with a Samsung EVO Plus 512GB. Works perfectly.Just bought an SE100, is the 400 gig card really the limit or has anyone tried a larger card?
1TB cards have been officially supported since the July 2019 firmware update.Just bought an SE100, is the 400 gig card really the limit or has anyone tried a larger card?
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
No optical output on the SE1001. Does it do optical output? I have looked into this and there is conflicting information. My attempts to connect it optically to Hugo 2 using Toslink to Mini Optical cable, have so far met without success, and the AK dealer in Australia says it regretfully cannot. When I play a track and look at the end of the cable there is no light emitting.
USB Mode is only for using SE100 as a USB DAC when connected to a computer. Once you connect, you want to press the External USB icon when you swipe down from the top. Once connected, it should say "USB Audio" under External USB Icon. You may need to press the External USB icon a second time after connecting in order to enable the USB out.2. Does it do USB output to an external DAC? I have tried a generic OTG cable from AK SE100 > H2 but again without success. When I go to USB Mode and try to select DAC Input, it will not allow me to tick this. I do find the switching confusing. Any advice on switching or the right cable to use?
