newworld666
Btw did you try the Fiio M17 as DAC only mode/Line Out SE/Balanced to more powerful amps? does it work flawlessly when using it on Windows 10, shows bit rate information when playing Flac/DSD files?
Also how is the Wifi streaming performance? any issues like KA?
No one WIFI issue like Kann Alpha with M17.. no obsolete Wifi hardware or android system !!!!
Works perfectly with a true line out balanced cable to a THX887 amp, or use an external DAC SMSL SU-9 +THX 887 => all DAC modes available (Coaxial) and with the USB-C port even more than M17 itself limited to 384Khz and DSD256, (but I don't have any DSD512 or 768Khz Flacs to really test the SMSL SU-9 other than just oversampling from neutron player).
It's possible to charge the M17 at the same time you use the USB-C output of the M17, with KA you can't use usb-c output and charge the KA at the same time... only spdif output can be used if you want to keep the KA chargesd with some DAC limitations and some worse THD.
Of course, I can use any smartphones, tablets, PC (mconnect/bubbleupnp/neutron/qobuz/tidal/foobar) and use the M17 as a full dlna renderer (even keep bit perfect & full DSD with Bubble Upnp/Uapp/Neutron Player through DLNA).
With a full android 10, you also have access to a full PEQ at system level like PowerampEQ or Wavelet far more powerful than the ultra limited KA PEQ.
