Luvdac
- Oct 14, 2013
Ps. I do get a ' scanningmedia' pop up briefly once the Kann comes on. If I add new albums to the card, the scanning can take upto 5 minutes.
Always format cards in fat32 and then use it in Kann. All other formats will not work and give your card error.Hi all,
New to the Kann, finally bit the bullet and picked one up to replace the otherwise buggy FiiO X5 mkIII. So far, I love it- but I have one small issue with the SD Card. I have a Sandisk 512 and it has about 130 gigs of free space currently on the card. It has been formatted at ExFat via a Macbook. It takes very long, upwards of 5 minutes, for the Kann to mount the card, which seems very slow and not a very good solution.
I've tried to reformat it using the KANN itself, as I did with my 256 card, but once the SD card is mounted, the option to erase the card under "system information" is still greyed out and it does not let me. ANy suggestions on how to get this card to mount faster and more smoothly- or is this just the way it is each time I boot it up? Thanks in advance!
Agree there Kann formats in Exfat and then shows as damaged card. Strange. This issue should be addressed ny Astell & Kern if they happen to read this post. Only format accepted whether the card is above 32gb and higher up it requires Fat32.Hi,
It can take 5 minutes when you insert the card. Once initial scan is done it only takes around 30 seconds or so. The issue I had with my sandisk 512gb card was the formatting. On exfat I had the same issues as you and at one point it showed the card as corrupted. I ended up formatting it ito fat32 and it solved all issues. The Kann itself formats the card to exfat, but then has issues with it. I formatted it to fat32 in my laptop and then inserted it in the Kann.
This is perfectly natural for "scanning media" pop upPs. I do get a ' scanningmedia' pop up briefly once the Kann comes on. If I add new albums to the card, the scanning can take upto 5 minutes.
Nope. There is no such method.Where would I find that?
There ought to be. If every time i start up a DAP it takes me 5 minutes to start playing a song, i wouldn't pay $100 for it. It seems to me to be counter intuitive to not have the ability of read NTFS and ExFAT formats. AFAIK and read people tend to avoid fat32 in most situations.Nope. There is no such method.
It just sounds soooo good!There ought to be. If every time i start up a DAP it takes me 5 minutes to start playing a song, i wouldn't pay $100 for it. It seems to me to be counter intuitive to not have the ability of read NTFS and ExFAT formats. AFAIK and read people tend to avoid fat32 in most situations.
Yeah. Best of luck with the formatting issue. It seems A&K may be the best DAP manufacturer but little software issues like these make a big dent. I dont know why they donot address these issues of Card Format type. I know these cards dont come cheap. If A&K person ( Jason) reading this post please try to rectify this ongoing issue in your next software update.Jeebers,now it says the sd card is damaged and it doesn't show up at all.I've been using it for weeks every day with no issues but it is in exFat.So now I will have to try and format it to Fat32.The last time I tried formatting to Fat 32 I destroyed a brand new 512 card,kinda expensive at around $400 but it was replaced for free.I had a lot of problems trying to get to Fat32 so after the sd card issue I tried exFat and that worked for awhile,not today.Not impressed.It shouldn't be this difficult to get a 512 card to format to Fat 32.Windows won't do it.I'll have to try a command prompt method and just hope the 512 sd card doesn't get destroyed like the last time.Bah!
These days Windows too doesnot allow Fat32 format unless the card is below 32GB. You have to use a 3rd party software to format to Fat32. If you happen to use a mac computer follow the terminal commands I have listed in my post above if you scroll upwards.Very difficult for me to get to Fat 32,in fact I couldn't which is why I am using exFat.Had no problem getting the 256 to Fat 32 but not the 512.Now I have to try again and hope it doesn't destroy my card again. Oh well.
