Promenadeplatz
What is the fastest intensity when charging the KANN via USB-C (using an adapter rated 2.4A) .... is it 1.6A-1.7A the highest?
Are you using a charger that indicates the charging current?What is the fastest intensity when charging the KANN via USB-C (using an adapter rated 2.4A) .... is it 1.6A-1.7A the highest?
Don't wanna say this but
And I don't want you too either. What i want to see you write is something more like "I don't like my KANN And I'm moving on to something I do like" That way we could just find your posts in another thread.
You are just another paid actor from A&K! this company is a joke that's all I wanted to say to everyone.
Our dev team has identified the issue from the latest firmware update and is finalizing the procedures globally. Unfortunately the units affected will need to be sent to be wiped and new system files installed. It cannot be done by the user.
For those in the US/Canada, if you contacted our North America support team already, you will receive an email in the next day or two with information on returning your KANN for service. If you are in the US/Canada and have not contacted our support team, please do so via our support email at support@theinvixion.com
For the rest of the world, I would recommend contacting the dealer you purchased the player from or the authorized repair center in the region as they should now have the information on how to proceed to fix your unit.
Anyone any idea how to stop a constant tendency for my KANN to be scanning media?
Seems to be when both card slots are filled. Individually each card is fine in the unit.
Worst thing about it for me is battery drain, even in Sleep mode. Nice n warm though!
Music plays fine though, except the Album browser is incomplete. The Folder browser for each card is fine.
Have tried all I can think of, including Reset to Factory, which I can only do by turning off. Removing cards, turning on, waiting for internal media scan to complete and then can Reset.
Hoping perhaps next Firmware may help. I realise others have more serious bricking issues at the moment but its useful having information up here in case others have similar problems.
I also appreciate the attention @JasonNYC gives to this forum. This does not detract from the potential awesomeness of the KANN as a music player.
Best wishes from "north england" (as one of our politicians recently called it) to other users, especially waiting patiently for solutions.
I' reformatted both SD and MicroSD cards in the Kann
Not necessarily just 1TB cards.So it seems all the endless scanning issue has to do with having a 1tb card in it. When I replaced the 1 tb with the 512GB card that has been there since I bought it in 2017 every thing works like it should again. When I first started using the 1tb SD card there were some annoying things but it never went into endless scan until the 1.13 firmware so...
And Yes the 1tb card was formatted in the KANN before I loaded it with music. A&K should be able to fix this, the SP2k works just fine with 1tb card.
