Mine are SanDisk as well. One is a SanDisk Ultra 256GB microSDXC UHS-I card. The other is a SanDisk Extreme Pro 512 GB SDXC UHS-I card. Amazon was the actual seller for both, not just the fulfiller, so I think that lessens the chances of them being fake. Besides which, they actually do work. I have not had a single problem using them in my PC. Even after the Kann says they're damaged, they load and run in my PC just fine. And as long as I only do a single transfer after formatting them, prior to inserting them in the Kann, and don't remove them again, they work in the Kann without a hitch. It's only the removal, new data transfer and reinsertion that's causing the problem, so I'm thinking this is a quirk with the Kann FW.
I'd take a look at my cards to see if they have any fake identifiers, but that would require actually removing them from the device, and well, you know...
