Color Availability: Silver & Blue
Technical Features:
- Single AKM AK4490 DAC
- Native DSD playback up to DSD256 (11.2mHz)
- PCM audio playback up to 32bit/382kHz
- Built-in amp with normal/high gain switch: drive the most demanding headphones with ease!
- Lowest output impedance of any our portable high-res audio players: Single-ended 3.5mm: 0.65Ω / Balanced out 2.5mm: 1.3Ω
- USB Type-C support (charging & data transfer)
- Micro USB for USB audio out & USB DAC
- Dedicated Line Out (2.5mm balanced & 3.5mm single-ended)
- 64GB internal flash memory
- Micro SD card support up to 256GB
- Full size SD card support up to 512GB
- aptX HD Bluetooth codec support
- 4" WVGA 800 x 480 LCD touch screen
- Long battery life: 6,200mAh 3.7V Li-Polymer Battery (up to 15 hours)
**Limited Time Offer**
Pre-order your KANN and receive a FREE 256GB full size SD Card!
*Limited quantities available. Offer valid while supplies last.
PRICE: USD$999https://us.astellnkern.com/products/kann
View at 4:35
Size Comparisons
