Tidal uses Amazon AWS, which has been down the entire day. Service is slowly being restored.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
Congratulation to your Naim.No problem here except for the constant skipping on my KC.
No problem with steaming tidal on my new naim uniti he, just that qobus still sounds better than Tidal
What do you mean by using it as a transportAK70 (1st Gen) is my favorite DAP after the in-a-class-by-itself Kann Cube, but I've always used it as a music transport matched with either the Cypher Labs Theorem 720 or Centrance Hifi M8. I agree with your assessment of the Cube, it's amazing.
Hey this is an interesting post. I have the opportunity to buy the cube and the one thing that's holding me back is that I'm not sure if I can use it in my hifi system. Are you saying that if i connect via toslink to my standalone dac i can bypass the cubes dac ? This is what I would like to do but i don't know if it will workIt depends on the very nice hi-fi system.
If its DAC section is better than the one in the Cube, use an optical Toslink cable. Connect one end to the Cube's 3.5 port, the other end to the Toslink input of the hi-fi. You may have to buy an appropriate cable, or a toslink/3.5mm adapter to a normal toslink cable. This case a digital PCM signal is transmitted from Cube to hi-fi, which is not sensitive to electrical noise. The D/A conversion happens on the hi-fi.
If you want to benefit from the super DAC of the Cube, use the 3.5mm output with a 3.5mm to RCA electrical cable.
As far as I understood the different explanations I've read so far, balanced output shall not be connected to single ended input, it may even damage the amplifiers.
I suspect the wired connection will give better results than aptxhd - in that case the small bluewave makes the D/A conversion, plus some compression applies from aptxhd. Please keep us updated, including what hi-fi you have.
It will work. That is how I use it with Burson Conductor 3XR.Hey this is an interesting post. I have the opportunity to buy the cube and the one thing that's holding me back is that I'm not sure if I can use it in my hifi system. Are you saying that if i connect via toslink to my standalone dac i can bypass the cubes dac ? This is what I would like to do but i don't know if it will work
How much longer is the battery life and how long does it now take to fully charge?More powerful and dynamic. Quieter, darker background. Longer battery life.
Nevermind. Somehow the ship righted itself.Hi @JasonNYC
I seem to be reliably seeing a problem where attempting to play music (any song at all) causes the Kann Cube to instantly crash (resulting in a complete power off). This is with the 1.33CM firmware.
At this point it’s basically a brick that doesn’t do anything.
Any suggestions? The unit is no longer under warranty.
audio-
Lol, @JasonNYC, my Cube seems quite unusable.Nevermind. Somehow the ship righted itself.
(Clueless)
I just got a notification on my Hiby R8 from the Qobuz app, that android 4 and 5 will not be supported any more starting 1st February.I think I have found something.
I have downloaded the tidal 2.31.0 version (apk) from apkmirror.com and installed successfully. This is the last version marked for Android 5.0+. The next tidal version, the 2.32.0, is marked for Android 6.0+. After putting this .apk into the OpenService folder of the Cube it does not even appear in the Service menu as available for install.
My suspicion is that the A&K firmware is based in Android 5, that is why it is not possible to install anything what requires Android 6.0 as minimum.
One more finding about the new firmware 1.26CM : when using the Cube as USB DAC the battery is constantly depleting even if it is connected to the USB C slot of the desktop computer, and showing the charging sign inside the battery icon. On the previous firmware the battery level was increasing when connected to the same port.
At this point the Cube will become useless to me. Implementation of Roon endpoint would fix it but they are not going to do it either. Kann Cube framework has been abandoned by A&K long ago, even on this forum it is almost impossible to get any answers.. I do not think I would ever be tricked again into buying anything A&KI just got a notification on my Hiby R8 from the Qobuz app, that android 4 and 5 will not be supported any more starting 1st February.
I expect that it will the end of Qobuz usage on the Cube .
