Curse them!
oh well
oh well
DAC out on the Kann cube is 5pin XLR, using line out is yikes since, with daps, the signal is fed through the amp section, meaning you would be double amping.Im thinking of buying this DAP for my WA8 as a source. My question is if the line out on the KAnn Cube is 3.5mm? Furthermore, can I send DSD256 natively via line out to the WA8?
Kann cube can play DSD256, can send it to the SE 3.5 line out, which is a fixed value amping.Im thinking of buying this DAP for my WA8 as a source. My question is if the line out on the KAnn Cube is 3.5mm? Furthermore, can I send DSD256 natively via line out to the WA8?
I guess if you had the misfortune of owning a dynamic, you would also be fooled by the glowy tubes of Woo audio.Hey Gabe,
Thanks for clarifying the peculiarities of the Cube, much appreciated! As for the quandary of single ended amps, once I shelled out 4k for one that drove the HD800 like nothing else. And it was considered the top3 amps, all time!
Just curios, how did you come to the conclusion that SE amps cannot, in fact, worth, like 2k or above?
Got any recommendations for a transportable tube amp?I guess if you had the misfortune of owning a dynamic, you would also be fooled by the glowy tubes of Woo audio.
The fact of the matter is if Wu thinks adding ballasts resistors and not killing headphones degrades the sound, then you can only imagine how much of a meme every other product he makes is.
Not sure who considered your SE amp to be in the top three, but I'm willing to guess it was either r/headphones or headphone headquarters, the kinda place that would unironically shill a dynamic.
And I hope you truly enjoy every second of your bass distortionRight-o! Enjoy your music!
I have Spotify version installed and working: 8.5.13.637.Hey all,
I was trying to install the Spotify APK. It was difficult to find the APK from a trusted source (APKPure only linked to the Google Play store). So I found an Android phone and downloaded it there. Then I used an APK backup utility to extract the APK and then used that to copy over to the KANN CUBE. So I have v8.5.51.941 of the Spotify app which should be the newest version.
Unfortunately, after installing it, the app would launch and hang for a second and then crash. Does anyone know what version of the APK works on KANN CUBE? Or how to get this version to work?
Thanks!
I must have the .apk file somewhere.
I downloaded and installed this (8.5.51.941) a minute ago, and now playing music. Try this and tell if you like it.Where did you get it?
This link does not work if you are in North America or certain other countries. For some reason, they have removed access to Spotify for certain countries. We are looking into alternatives for those people that reside in North America and other countries that cannot access Spotify through APK Pure.I downloaded and installed this a minute ago, and now playing music. Try this and tell if you like it.
https://apkpure.com/spotify-music/com.spotify.music/download/57678268-APK?from=variants/version
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
