Exit
- Feb 16, 2014
possible to share the contact person? so that I can reach him/her...
See inbox
I bought mine only yesterday from Selfridges London, they told me they've had no returns so far. The serial number is with a 4...
I asked my local dealer and he told me there is no recall and if there is any issue I should bring it back. Perhaps a proper recall is what they need than waiting for people unit to fail and than having them go thru the headache, in particular where the unit might die weeks after the end of the warranty period.
I have been struggling to get a good fitting so far. I may have to return to Amazon. If I do, I will hygienically clean the tips I used, but can anyone remember if it was medium or small that came on them from the start?
Also am I right to think the long flange side of the tips is what goes into "free air" and the shorter flange side touches the back of the driver shell? I assume it must be that way around because with the large tip, if the longer side is touching the back it covers the L and R markings.
Sound is most definitely changing in the first couple of hours even.....surprising really as it's the first IEM I have had where any change is so dramatic.....
Still worried that a 11xxx serial can't be a good one but in my efforts to find good fit, I have been pushing, pulling over and over and over......
No the longer ones cover the housing, you could try the included comply too.
I use stock tips and I didn't even change from the original ones that is in place, fits so snuggly, best isolation since SE215 for me cause I used IE800 and MDR-EX1000 before.
I must have funny shaped lug-holes Seriously though, this is the first IEM where I have struggled to this extent. It may have something to do with the oval shaped silicone tips and my ear holes are just not shaped that way!
